Dial Mode in CUCM
I installed a 7.0.2  CUCM IP Telephony platform in a company that have an Avaya PBX. In Avaya platform it is possible to dial to internal numbers without off-hooking the phone and without pressing any other key. The user just type the internal number (the phone is on-hook) and the call is placed.
Is there any way to do this in CUCM?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: Dial Mode in CUCM
Unfortunately no, in Cisco world you dial the phone and then press dial softkey if you want that without going off-hook.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
173
