dial-patterns dialing 9 first
vgioia5090
how do i tell the cme not to require a 9 to dial a call?
8 Replies 8
Michael Owuor
Vito,
Under telephony-service, remove the "secondary-dialtone 9" command, then verify that your dial-peers for those calls are also configured to route calls without expecting a 9 at the beginning of the number.
Hope this help.
Michael.
thanks for your help Michael, just one more thing which part of the dial-peer do i change to reflect them not to expect the 9?
Can you post what your dial-peers look like?
here you go thanks!
dial-peer voice 1 voip
translation-profile outgoing services
destination-pattern 9[49]11
session protocol sipv2
session target dns:callcentric.com
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 2 voip
translation-profile outgoing Local10
destination-pattern 9772[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3 voip
translation-profile outgoing Local7
destination-pattern 9[2-9]......
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 4 voip
translation-profile outgoing LongDistance
destination-pattern 91[2-9]..[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
To remove 9 from your dial-peer eg.
change to :
destination-pattern [49]11
also, how can my sip provider requires me to dial the area code for local numbers, how can i have cme append the area code so i can just dial the local 7 digits?
u can add the command
prefix 1234
while 123 is any digits u wants
add it to the dial-peer
or u can make atrnaslation profile if u wanna prepend 55
voice translatio-rul 1
rule 1 /\(.*\)/ /55\1/
voice translation profile p1
translate called 1
dial-peer voice 9 voip
translation-profile outgoing p1
good luck
hope this helps
hi, thank you, i tried the prefix command but ccme states its not an available option. i can try the translation rule but im not sure how to implement it. my provider wants me to dial 1772 for every call. also i already have some rules in place, i will upload them.
thanks so much for your help...
voice translation-rule 1
rule 1 /9911/ /911/
rule 2 /9411/ /411/
voice translation-rule 2
rule 1 /9772+/ /1772/
voice translation-rule 3
rule 1 /9+/ /1772/
voice translation-rule 4
rule 1 /91+/ /1/
voice translation-rule 5
rule 1 /17772503459/ /101/
voice translation-rule 7
rule 1 /1../ /17772503459/
voice translation-profile CALLCENTRIC_Incoming
translate called 1
voice translation-profile Incoming
translate called 5
voice translation-profile Local10
translate calling 7
translate called 2
voice translation-profile Local7
translate calling 7
translate called 3
voice translation-profile LongDistance
translate calling 7
translate called 4
voice translation-profile Services
translate calling 7
translate called 1
