Community Member
dial peer configuration (auto stripping)
HI,
I am facing issue with my h.323 gateway. I am trying to call a number 01147771171 from my ip phone. and it is not going through. When i checked on the gaetway it is showing the called party number as 47771171, it is triping 011 from the pattern.
Please find below the dial peeer config
dial-peer voice 16 pots
destination-pattern 0[1-6].........$
port 0/0/0:15
forward-digits all
and the output from debug isdn q931
NDArouter_01#
Jul 16 08:42:07.144: ISDN Se0/0/0:15 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 2
Jul 16 08:42:07.144: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x02F3 callID = 0x8276 switch = primary-4ess interface = User
Jul 16 08:42:07.144: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x02F3
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x2181, '1001'
                Plan:ISDN, Type:National
        Called Party Number i = 0x91, '47771171'
                Plan:ISDN, Type:International
Jul 16 08:42:07.164: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x82F3
Please help me on this.
Pawan Arora
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Super Bronze
Ok, your provider still doesnt like that..can you try unknown..
Int s0/0/0:15
isdn map address ^011* plan unknown type unknown
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
Re: dial peer configuration (auto stripping)
hi,
use: no digit-strip
regards
Community Member
i have applied that command also but got the same
no digit-strip
port 0/0/0:15
forward-digits all
here is the output
Jul 16 08:57:17.059: ISDN Se0/0/0:15 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 2
Jul 16 08:57:17.059: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x031A callID = 0x829F switch = primary-4ess interface = User
Jul 16 08:57:17.059: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x031A
                Standard = CCITT
        Channel ID i = 0xA9839C
                Exclusive, Channel 28
Jul 16 08:57:17.083: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x831A
Jul 16 2012 14:27:18: %ISDN-6-DISCONNECT: Interface Serial0/0/0:30  disconnected from 9818849802 , call lasted 43 seconds
Jul 16 08:57:18.331: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0316
        Cause i = 0x8090 - Normal call clearing
Jul 16 08:57:18.379: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8316
Jul 16 08:57:18.383: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0316
Jul 16 2012 14:27:20: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 8130680797 , call lasted 28 seconds
Jul 16 08:57:20.927: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0318
Jul 16 08:57:20.979: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8318
Jul 16 08:57:20.983: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0318
Jul 16 08:57:22.283: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x031A
Jul 16 08:57:22.331: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x831A
Jul 16 08:57:22.335: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x031Au all
All possible debugging has been turned off
NDArouter_01#term no mon
Community Member
HI,
I have made some changes and it takes the 011 but my calls are not going through
no digit-strip
port 0/0/0:15
forward-digits all
prefix 011
ISDN 931 debug:
Jul 16 09:05:29.971: ISDN Se0/0/0:15 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 2
Jul 16 09:05:29.971: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0336 callID = 0x82BC switch = primary-4ess interface = User
Jul 16 09:05:29.971: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0336
                Standard = CCITT
        Called Party Number i = 0x91, '01147771112'
Jul 16 09:05:29.995: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8336
Jul 16 09:05:36.211: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8336
        Cause i = 0x8483 - No route to destination
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Jul 16 09:05:36.215: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x82BC
Jul 16 09:05:42.455: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0336
Jul 16 09:05:42.467: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8336u all
Hi, from the logs it showing that your teleco is unable to route the call, i.e the number is unroutable.
Make sure that you are sending the right number (LD, National, or international). Else, you may check this with your teleco.
Community Member
But earlier it was working fine..
Blue
HI
I believe your CUCM is changing National call to International call. Your service provider is expecting that
Plan:ISDN, Type:National and not international.
Check your CUCM and  convert it in National. May be your service provider added this criteria newly.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Community Member
Hi Ronak,
How can i check on the call manager? is there any pareameter for this
Blue
HI
In your route pattern , select as below. Change Type to National .
Ronak Patel
rate helpful posts.
VIP Super Bronze
Pawan is this an international call? Your provider is saying they ant route the call
Community Member
no this is national dialing number
VIP Super Bronze
Then your isdn plan type is wrong. It is showing as international. You need to change it to either national or unknown.
VIP Super Bronze
Configure this on your gateway:
Int s0/0/0:15
isdn map address ^011* plan ISDN type National
Community Member
I have changed it to national and still call is not going through...in the debug it is showing national
VIP Super Bronze
Please send "debug isdn q931" only.
Community Member
Here it is
Jul 16 10:14:45.692: ISDN Se0/0/0:15 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 2
Jul 16 10:14:45.692: ISDN Se0/0/0:15 Q931: pak_private_number: Invalid type/plan 0x0 0x8 may be overriden; sw-type 2
Jul 16 10:14:45.692: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x03B9 callID = 0x8341 switch = primary-4ess interface = User
Jul 16 10:14:45.692: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x03B9
                Standard = CCITT
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Called Party Number i = 0xA1, '01147771112'
Jul 16 10:14:45.716: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x83B9
Jul 16 10:14:57.764: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x83B9
Jul 16 10:15:04.252: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x83B9
        Cause i = 0x849C - Invalid number format (incomplete number)
Jul 16 10:15:04.252: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8341
Jul 16 10:15:08.308: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x03B9
Jul 16 10:15:08.320: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x83B9u all
VIP Super Bronze
Int s0/0/0:15
Community Member
its working now, thanks for your support.
1097
