dial peer configuration for SRST router and h323 gateway
Hi All,
Could somebody help with the configuration
I'm integrating call manager with the h323 gateway.
For call manager there is route pattern with
0.[1-9]! point to h323 gateway, with pre dot digit manipulation
and the voice gateway configuration is below
dial-peer voice 101 pots
preference 3
destination-pattern .T
port 0/0/0
dial-peer voice 102 pots
preference 2
port 0/0/1
dial-peer voice 103 pots
preference 1
port 0/0/2
this configuration is running when in the call manager mode
but whenever is on srst mode, the ip phone cannot dial with the access code "0" and then number to call.
but ip phone can dial without access "0"
what configuration that I should make to make ip phone can dial the same with SRST mode and CCM mode. this is with access code "0"
thanks before
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: dial peer configuration for SRST router and h323 gateway
Correct, explicitly matched digits in destination pattern of a pots dial peer get automatically stripped, so what I provided will accomplish what you are looking for.
Chris
Change CUCM not to strip preDot.
Chris
And adjust
destination-pattern 0.T
Chris
Hi Chris Deren,
thanks for the advice, I'll try it in a maintenance windows.
for example we dial 031900717 for local call.
we must to send 31900717 (without access code) to the provider.
if we send 031900717 (with access code) the call is rejected by the operator.
For sure, for  destination-pattern 0.T mean 0 is sent to the provider or not?
Thanks before chris
Chris
333
