Dial Peer Configuration Help
On an H323 gateway what dial peer do I need to configure to route an inbound 800 number that is coming in on a CAS T-1 sending the last four digits as the DNIS. Currently this T-1 is only being used for outbound traffic.
Dianna
  • IP Telephony
Hall of Fame Super Gold
Re: Dial Peer Configuration Help
Like:
dial-peer voice 1234 voip
destination-pattern 1234
session target ipv4:x.x.x.x
codeg g711u
no vad
dtmf-relay rtp-npe
Please rate post if it does!
This didn't work for me. When calling the number I get dead air, no ring back.
VIP Super Bronze
can you post your full config here
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Attached id my current config. It is configured in call manager.
Thanks for the help.
Dianna
Does the CM knows about the called DID?
Next step would be debugs like "cch323" with "term mon".
num-exp
VIP Super Bronze
Your dial-p voice 411 below specifies a 4 digit number. However you said the inbound number is 800
can you tell me the full number delievered to your gateway.
You can know this by doing a dbug isdn q.931 and place a test call to the number...
dial-peer voice 411 voip
destination-pattern [0-8]...
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
session target ipv4:10.34.0.11
This is the message I got when I did the debug and called the number. Telco is suppose to be sending 4191 as the dnis. The whole number is 877-367-4191
Dianna
Jul 11 13:46:09.132: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8 callref = 0x807D
Jul 11 13:46:09.168: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x007D
Jul 11 13:46:09.168: ISDN Se0/0/1:23 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 2 call id 0
x28CC
VIP Super Bronze
I need to see the full debug..including the part that showed the calling and called number and also the cuase code..
send the full output
151
