Community Member
Dial Peer configuration
Folks, when I try to add a dial peer to a
cisco 3825 running IOS c3825-spservicesk9-mz.124-11.T4.bin
I get the following error:
ERROR: could not add peer
Do you know what do I need to do ?
thank you
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Dial Peer configuration
No, it's a bug. reload the router and you will be able to add the DP.
I have seen this error before, and usually its because you dont have enough memory left to add another dial peer.
Community Member
that's what I thought
hq-3825-voip#show memory free totals
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 65A72950 137942704 127195068 10747636 10316808 8275968
I/O 2DE00000 35651072 11544380 24106692 22423504 23751420
do you think I need to add more memory ?
thank you
Community Member
that solved my issue
thank you
No sweat. If you could convince that TAC that's a bug and get it filed, that would be a big favor to the community. Unfortunately it's very difficult.
Thanks for the nice rating and good luck!
You ran into a memory leak that to my knowledge has not been fixed yet. I have encountered it on all releases but 12.4XC. Only solution is reload the router, but it will happen again.
So if you don't want to downgrade, preconfigure all the DPs that you plan to need in the future.
353
