Dial-Peer DNS SRV
I trying to reduce the amount of dial-peer that send calls to the cucm from the itsp. I currently have 2 dial-peers pointing to 2 different call managers.
I tried to change the ip with dns.
OLD Dial-peer
dial-peer voice 50 voip
description "TO PRIMARY Call-Manager"
destination-pattern 10001
session protocol sipv2
session target ipv4:192.168.1.10
voice-class codec 16
dtmf-relay rtp-nte
no vad
dial-peer voice 51 voip
description "TO SECONDARY Call-Manager"
preference 1
session target ipv4:192.168.1.20
dtmf-relay rtp-nte
no vad
I changed it to:
description "TO Call-Manager's"
session target dns:CUCM.example.com
dtmf-relay rtp-nte
no vad
I can ping the CUCM.example.com from the gateway and in the dns server the below is registered:
NAME                                    Port                Weight           Priorty                IP
CUCM01.example.com----------->5060------------->10--------------->50------------------>192.168.1.10
CUCM02.example.com----------->5060------------->10--------------->50------------------>192.168.1.20
CUCM03.example.com----------->5060------------->10--------------->50----------------- >192.168.1.30
CUCM04.example.com----------->5060------------->10--------------->50------------------>192.168.1.40
But when I try it invalid number and CUCM is not depended on DNS.
ITSP ------->CUBE ------------>SIP-TRUNK-------->CUCM
Is there anything I'm missing?
Dial-Peer DNS SRV
Hello Zekeria,
Refer to below doc, this will may help you.
http://ben.thepolzins.us/2010/02/06/using-dns-srv-records-with-ios-dial-peers/
Merry Christmas !!
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Hall of Fame Super Silver
Re: Dial-Peer DNS SRV
In addition if your IOS is 15.1 or newer make sure you add hosts to toll fraud list as unlike with destination pattern defined under dial peers as IP addresses which do not require explicit listing, when using SRV they do.
Chris
1071
