Dial-peer Doubt!
Hi People
A quick doubt!
What's difference between:
dial-peer voice 1 pots
destination-pattern 2001
and
destination-pattern 2001$
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Dial-peer Doubt!
To disable variable-length matching for a dial peer, add the dollar sign ($) to the end of the destination pattern, as shown:
dial-peer voice 1 voip
destination-pattern 555$
session target ipv4:10.10.1.1
The $ character in the configuration prevents this dial peer from being matched for dial string 5551212 because the extra digits beyond 555 are considered in the matching.
With two-stage dialing, the router collects the dialed string digit by digit. It attempts to match a dial peer after each digit is received. As soon as it finds a match, it immediately routes the call. For example, given the following configurations, the router would immediately match dial string 5551212 to dial peer 1.
dial-peer voice 2 voip
destination-pattern 5551212
session target ipv4:10.10.1.2
from
http://www.cisco.com/en/US/docs/ios/voice/dialpeer/configuration/guide/vd_dp_feat_cfg_ps6350_TSD_Products_Configuration_Guide_Chapter.html
HTH,
Chris
Dollar sign ($)-Disables variable-length matching. It must be used at the end of the dial string.
java
if this helps, please rate
java
www.cisco.com/go/pdi
from
HTH,
Chris
403
