Dial-peer for 7-digit DID to 4 digit conversion
44golf58
The Telco is sending 7 digits for DID over PRI that we convert to 4 digis, which works ok from the MGCP gateway settings. But in SRST mode, we need to convert 7 to 4 with a Dial-peer and translate some of the numbers. Does anyone have a dial-peer and related translation example?
thanks.
Brandon Buffin
If your DIDs match up with your extensions, one option is to use the dialplan-pattern command under call-manager-fallback, such as:
dialplan-pattern 1 1231... extension-length 4
In this example, 1231234 would get translated to extension 1234. If that doesn't work, what kind of translation do you need to do?
Hope this helps. If so, please rate the post.
Brandon
crodriguez
jbarcena
Level 9
Level 9
You can also use the num expand command:
num-exp 245090. 090.
tim_roper
Hopefully, you've already solved the problem, but I'll post this for anyone else searching for the same solution...try the "alias" command under call-manager-fallback.
alias 1 21033344.. to 5350
alias 2 2103335555 to 5350
The command is explained at the following URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/command/reference/srstcr.html
