Dial-peer for faxing match
Hi all, I am kind of newbie to the voice world and I needed some help setting up my dial-peers:
I have a call manager managing all my voice calls and I have also a SIP faxing software for sending faxes out, what I needed is when I am sending out faxes to match the correct dial-peer, but ny config right now is matching always the dial-peer for the call manager. could you help?
Config:
my service voice:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback none
h323
sip
my call manager dial peer:
dial-peer voice 1 voip
destination-pattern 12..
session target ipv4:10.0.4.32
incoming called-number .
dtmf-relay h245-alphanumeric
what should be my faxing out dial peer:
dial-peer voice 210 voip
answer-address 014611201
session protocol sipv2
session transport udp
dtmf-relay h245-signal
codec g711ulaw
fax rate 14400
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback cisco
clid network-number 014611201
no vad
here's an example of my SIP debug when using the fax software:
INVITE sip:123434@10.0.4.34 SIP/2.0
Via: SIP/2.0/UDP 1201:5060;branch=z9hG4bK1008
To: <sip:123434@10.0.4.34>
Call-ID: 22f205f9-c768-4ae2-aabc-15885e36ba0f@1201
CSeq: 1 INVITE
Max-Forwards: 70
Contact: <sip:0001@1201:5060>
User-Agent: Net Satisfaxtion/IP_FAX-8.5.4840.684
Allow: INVITE, ACK, BYE, CANCEL, REFER, NOTIFY
Content-Type: application/sdp
Content-Length: 148
v=0
o=IPFax 0 0 IN IP4 1201
s=SIP Fax Call
i=IPFax
c=IN IP4 1201
t=0 0
m=audio 49156 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
a=sendrecv
Re: Dial-peer for faxing match
Multiple things going on here:
1) Incoming called number will always match before answer address. If you want to match with answer address 'incoming called-number .' can't exist anywhere. You would need to use answer-address to also match CUCM dial peers.
2) Your DTMF for your incoming fax dial peer isn't going to work because SIP endpoints do not use H245.
3) You may be able to get this to work by putting the fax protocol configuration under your CUCM dial peer. Adding fax capabilities won't break anything with CUCM.
4) Take 'fallback cisco' off your fax protocol configuration, as your fax server doesn't support it.
-nick
Hi, thanks for you reply.
Is there any document you can refer to me regarding the proccess for choosing a dial-peer?
Also I've tested configuration putting in a specific incoming called-number for the fax dial peer (just for testing purposes) and it worked fine.
I was thinking of following your advice and removing the incoming called-number . from the call manager dial-peer, will this break anything?
Here are all my dial-peers
dial-peer voice 2 pots
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
dial-peer voice 200 pots
service onramp-sffax
incoming called-number 1201
direct-inward-dial
dial-peer voice 201 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 1201
information-type fax
session target mailto:fax@dataelec.com
image resolution fine
destination-pattern 9014611201
session target sip-server
codec g711ulaw
fax rate 14400
no vad
Here you go:
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
If you don't match an incoming dial peer it's possible for you to break things.
-nick
Thanks, it was not me that configured the voice gateway and I am trying to understand it's configuration so I can then make the changes I need.
Frim what I already gathered it seems to me that dial peers 1 and 2 are being used both for inbound and outbound matching. Peer 1, match for destination-pattern 12.. when making inbound calls and incoming called-number . for outbound, the same for dial peer 2 is matching destination-pattern 9T for outbound and incoming called-number . for inbound, am I right?
I think that if I want to remove the "incoming called-number ." statement for the dial peer 1 I would have to configure "answer address" or setup another dial peer for inbound matching for CM is that correct?
THanks for the help
You should remove incoming called number . if you would like to use answer address.
That leaves 4 options:
Match on a more specific incoming called number that would not intersect with what the fax server would dial (probably not an option)
Configure answer-address on dial peers for your CUCM DID (ANI from GW perspective) range.
Allow for dial peer hunt algorithm to use the 3rd rule, which is match the incoming dial peer against the CALLING number with a destination pattern. The idea here is that if you are pointing a dial peer to it, and the caller id matches it, you should probably use that dial peer. This is messy because often with translations or caller-id masks the numbers you route to CUCM are not the same as the caller ID you will receive. But it is an option.
The fourth is to use translations so that you can match your dial peers. This would be something like adding ## to the calling number and stripping it off your outgoing dial peer, but use it to match your incoming dial peer. Or, prefix numbers on your faxing dial plan and use that to match with an 'incoming called-number .T' This is a little more of a hack, but it's easier to configure and wrap your head around.
-nick
-nick
671
