Community Member
dial-peer help
I have calls coming in to a 3825 that look like this sip:##########
I want to do something like this:
dial-peer voice 14 pots
trunkgroup Local
destination-pattern sip:98[2-9]..[2-9]......
incoming called-number .
forward-digits 10
but it doesn't like the "sip:" in the pattern, what can I do to solve this?
Re: dial-peer help
you're configuring the wrong type of dial-peer, POTS is used for FXOs, FXS, T1, E1, etc. which you configure port x/x/x
you need VOIP dial peers to configure session-target and protocol sip
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: dial-peer help
I should be more specific, this is for an asterisk server sending sip/rtp to this 3825, to have the 3825 translate to TDM out a PRI.
I dont know exactly what the issue is, its like the 3825 is rejecting a connection from the asterisk server.
Re: dial-peer help
Did you allow SIP in the allow voice
voice service voip
allow-connections SIP
Community Member
Re: dial-peer help
no, Im not familiar with this. This router is in production, will configuring this command cause any issue with the current traffic?
Re: dial-peer help
Hi friend,
Check this link for dial-peer configuration.
It provides good info about what you can configure for dial-peer VOIP and POTS.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dpeer_c.html
- Adrián.
Community Member
Re: dial-peer help
hi, you may want to try something like this...
current
trunkgroup Local
forward-digits 10
Try this..
dial-peer voice 14 voip
trunkgroup Local
destination-pattern 98[2-9]..[2-9]......
forward-digits 10
This is one of mine...
dial-peer voice 1 voip
translation-profile outgoing services
destination-pattern [49]11
session protocol sipv2
session target dns:callcentric.com
dtmf-relay rtp-nte
codec g711ulaw
dns:domain.com or ipv4:XXX.XXX.XXX.XXX which would be the ip address of the sip trunk.
hope this helps.
167
