Community Member
Dial Peer Help
I have central call processing, 2 offices, each with their own GWs.
I am having trouble with international calls from one of the offices (Office A). My international Route Pattern (INT_RP)in CM is simply a 9.@ for Office A. For Office B (INT_RPB)it is 9011!
Both Offices only have 9. pots dial peers in GWs.
Is the problem that I need a dial-peer of 9011T in the GW of Office B??
Will rate Posts.
Re: Dial Peer Help
Hello:
What protocol are you using H323 or MGCP?
Community Member
Re: Dial Peer Help
H.323
Re: Dial Peer Help
Yes you would need a dial Peer 9011T on the gateway even if you have it on the CM. Just copy the existing dial-peer(do not forgot to change voice port info) from the working gateway to not-working gateway.
Community Member
Re: Dial Peer Help
Great. I will try this now.
Community Member
Re: Dial Peer Help
No luck. Still getting busy tone. I can post my dial peers if that helps?
Re: Dial Peer Help
Yes please, can you also post debug isdn q931
Community Member
Re: Dial Peer Help
I believe I captured enough from the call. Let me know if you need more. The called party was 011442077971076.
Thanks again!
Re: Dial Peer Help
Hello:
It says invalid number format as the error, can you post the dial-peer now from working and non-working gateway.
Cause i = 0x809C - Invalid number format (incomplete number)
Community Member
Re: Dial Peer Help
Interesting. Here is the dial peer I added to the GW that does not work. It is exactly the same as the other.
dial-peer voice 89 pots
destination-pattern 9011T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 1
progress_ind connect enable 1
direct-inward-dial
port 0/0/0:23
prefix 011
dial-peer voice 88 pots
preference 1
direct-inward-dial
port 0/1/0:23
prefix 011
Re: Dial Peer Help
Can you compare under the call manager administration page H323 Configurations for both working and non-working gateway setting for
1.Called Numbering plan
2.Calling Numbering Plan
Both of them should be Cisco Call Manger
Let me know
Community Member
Re: Dial Peer Help
Sorry, I am back. I attached a screenshot of the fields from the gateway configs in CM that I believe you were asking about. The page in the left is the one that does NOT work. There are some values that are different, could this be a problem? Are you thinking that those values be the same?
Thanks again for all of your help. I'll be esure to rate your assistance.
Silver
Re: Dial Peer Help
You may want to test them using unknown as well
Re: Dial Peer Help
Mostly probably yes, can you adjusting the values for the not working one according to the working one.
Let me know
Community Member
Re: Dial Peer Help
Yes, i am goign to make the changes. I can't do it right now because I will more than likely have to reset the gateway which will drop calls.
Standby, I will le tyou know how we make out.
Thanks again, I really appreciate you helping me out.
Community Member
Re: Dial Peer Help
Still no change, cannot place the international calls and the Gateway settings are matching. I double checked with my provider and we do in fact have international service.
I'm out of ideas. Any other thoughts?
Thanks again!
Re: Dial Peer Help
Have you tried a csim start and ran a debug on the ISDN and pots dial-peer? If the call is successful then you can rule out possibly any gateway config and look more at the configs on the ccm.
Community Member
Re: Dial Peer Help
Matt,
Not sure how to do that. If it's noty too detailed for you to do, can you send me a quick instruction on that.
Will rate post.
Community Member
Re: Dial Peer Help
are you discarding the 9 at the call manager? if not....do so.
remove the 9 on the dial peer
get rid of the prefix under the dial peer and add "discard-digits none"
Steve
Steve
Please rate all helpful posts.
Community Member
Re: Dial Peer Help
Steve,
Appreciate your input.
On the CM Route Pattern configuration I have discard digits as "Pre-dot" now, originally I had "none". I removed the 9 from the dial-peer and the prefix from the dial-peer.
Now at least I am getting a message fro the provider saying "call cannot be completed as dialed". Is there something else I need to present to them.
Will rate, thanks!
Community Member
Re: Dial Peer Help
can you send some q931 debugs?
Steve
Community Member
Re: Dial Peer Help
Try this dial peer
dial-peer voice 3125 pots
description International Dialing
preference 1
direct-inward-dial
port 0/0/1:23
prefix 011
Community Member
Re: Dial Peer Help
Really appreciate your input. I gave it a try and here's the debug q931 output. Any ideas?
Hall of Fame Super Gold
Re: Dial Peer Help
Hi, the problem is that the setup is sent as "international" type AND the prefix 011 is present, that is an invalid configuration.
The way it works, normally internatiol calls are "unknown" type and the 011 prefix.
OR, you set international type call, and the number begins with the country code and no prefix. But, I've never seen anybody doing that and I would no recommended that.
So you need to go into whatever CM or router config where you specified "international" and take it away.
Community Member
Re: Dial Peer Help
Understood. Do you hapeen to know where this specific setting might be located? I attached a screenshot of my GW setup for outbound. I am running H.323 and my route pattern is just a 9.@ for international. I also noticed the "Route Filter" which I am not familiar with.
244
