dial-peer ignoring translation-profile at AS5400XM
Im configuring an AS5400XM and im having some problems with diak-peers ignoring Voice translation-profiles outgoing, I want to translate for example the called 5212322808 to 2808. To test Im using
#csim start 5212322808. Below is the configuration and debug.
THANKS
voice translation-rule 10
rule 1 /^521232\(26[4-9].\)/ /\1/
rule 2 /^521232\(28[0-5].\)/ /\1/
voice translation-profile CYRA
translate called 10
dial-peer voice 50001 voip
description =====================> VOIP TO TUCCCMSUB01
translation-profile outgoing CYRA
preference 3
service session
destination-pattern 52123228[0-5].
voice-class codec 1
session target dns:TUCCCMSUB01
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
ip qos dscp cs3 signaling
no vad
DEBUG
*Mar 31 03:09:37.487: xrule_checking
*Mar 31 03:09:37.487: xrule_checking calling , called 5212322808
*Mar 31 03:09:37.487: xrule_checking peer_tag 50001, direction 2, protocol 0
*Mar 31 03:09:37.487: xrule_checking Return rc = -5
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: dial-peer ignoring translation-profile at AS5400XM
Yes, remember that csim will ignore translation profiles on DP, yet these configure at port or trunk level will work.
Silver
The calls are not getting matched to any of the translation profile. could you verify the configuration details.
You can refer this configuration guide for more information on configuring Translation profiles.
http://cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
http://cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Thanks for the reply,
It was weird, becuase when I test the dial peers and the translations both work fine, but failed when I tried to make a test call using csim start, Now Im seeing that making a call from any other place (instead inside the router) it just work.
Well, Thanks all for the support.
113
