Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Dial peer issue
I am having a problem where a call comes in and it will not match my incoming called number . dial peer. I am switching them from an old fax solution to Xmedius.
Basically if I call XXX-XXX-1734 (one of their fax numbers) it will not route to the incoming dial peer I have configured. It routes to the default dial-peer 0 and I get a slow busy signal. If I call XXX-XXX-6211, it will ring to Xmedius and faxes can be made. It only happens on the 17XX numbers. I included the config and some debugs that I ran.
thanks
Re: Dial peer issue
debug voice cc inout
Bronze
Re: Dial peer issue
Put this in:
dial-peer voice 70 pots
incoming called-number .
direct-inward-dial
port 0/0/0:10
dial-peer voice 71 pots
direct-inward-dial
port 0/0/0:11
Your dial-peer voice 3 looks ok, but it doesn't specify the port.
133
