05-18-2009 02:03 PM - edited 03-18-2019 10:21 AM
hello,
I have an issue with dial-peers, when i call one of my did's i get dial tone, the last 4 digits of the did are 8084
dial-peer voice 17 voip
preference 1
destination-pattern [1-8]...
session target ipv4:<ccm-ip>
dtmf-relay h245-alphanumeric
dial-peer voice 18 voip
preference 2
dial-peer voice 1 pots
incoming called-number .
port 0/1/0:23
dial-peer voice 2 pots
destination-pattern 9T
port 0/1/0:23
dial-peer voice 9011 pots
destination-pattern 9011T
port 0/1/0:23
dial-peer voice 11 voip
destination-pattern 8480
what's wrong?
thanks
Solved! Go to Solution.
05-18-2009 02:21 PM
Add the command "direct-inward-dial" to dial peers 1 and 2.
Hope this helps.
Brandon
05-18-2009 02:21 PM
Configure:
dial-peer voice 1
direct-inward-dial
Incidentally, you do not need to specify port for DP 1.
05-18-2009 02:21 PM
Hope this helps.
Brandon
05-18-2009 02:21 PM
Configure:
dial-peer voice 1
direct-inward-dial
05-18-2009 04:04 PM
Hi friend,
Just to contribute a little bit in this thread, you can get information about direct-inward-dial (DID), so you can understand what was causing the issue in your voice gateway.
Understanding Direct-Inward-Dial (DID) on IOS Voice Digital (T1/E1) Interfaces:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00801142f8.shtml
Cisco CallManager: Understanding Direct-Inward-Dial (DID):
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00801c43f6.shtml
Best regards,
- Adrián.
