Community Member
Dial peer Issue..
Hi, we are using h.323 VGW.I have dial peer as below.
dial-peer voice 1 pots
destination pattern 9T
port 1/0:15
if i dial a number like 922979291, it will match the dial peer and will it discard digit 9 and send the digits (i.e 22979291)or it will send all the digits (i.e 922979291)including 9?
Re: Dial peer Issue..
POTS dial peer discard all non wildcard digits, so in your example will forward number without 9.
rate if this help
add one of the bellow command and will work as you want
prefix 9
or
forward-digits all
hope this helps
155
