Dial-Peer matches but fails to call out
Am trying to get my CME configured for Callcentric.  I have both an inbound and an outbound plan.
With my dial-peers configured for standard 11-digit and 10-digit dialing, calls go to fast busy after all digits except the last two are dialed.  Debug shows a dial-peer match initially, then states no match and the call fails.  If I change the destination pattern to match my cell phone number exactly, I can dial all the digits but the call still fails.  Anyone have a suggestion?
Here are my dial peers:
dial-peer voice 700 voip
description SIP Trunk - Incoming
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target dns:callcentric.com
incoming called-number .%
dial-peer voice 701 voip
description SIP Trunk - Outgoing 3-Digit Calls
translation-profile outgoing SIP_1
preference 1
destination-pattern 9[2-8]11
voice-class codec 1
session target sip-server
dtmf-relay rtp-nte
dial-peer voice 702 voip
description SIP Trunk - Outgoing 11-Digit Calls
preference 1
destination-pattern 91[2-9].......
dtmf-relay rtp-nte
dial-peer voice 703 voip
description SIP Trunk - Outgoing 10-Digit Calls
preference 1
destination-pattern 9[2-9].......
voice-class codec 1
no vad
And here is the debug associated with a call:
*Dec 26 22:26:27.854: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7018, Called Number=, Voice-Interface=0x4A4AE7B0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20009
GMIT-VOICEROUTER01#
*Dec 26 22:26:29.526: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9
   Result=Partial Matches(1) after DP_MATCH_DEST
*Dec 26 22:26:29.526: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
*Dec 26 22:26:29.914: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=91, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=91
*Dec 26 22:26:29.914: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
*Dec 26 22:26:30.174: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Numbe
GMIT-VOICEROUTr=, Called Number=912, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=912
*Dec 26 22:26:30.174: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
*Dec 26 22:26:30.514: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9120, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9120
*Dec 26 22:26:30.514: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
*Dec 26 22:26:30.822: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=91207, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=91207
*Dec 26 22:26:30.826: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
*Dec 26 22:26:30.826: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
*Dec 26 22:26:31.342: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=912072, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=912072
*Dec 26 22:26:31.346: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
*Dec 26 22:26:31.346: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
*Dec 26 22:26:31.542: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9120722, Peer Info Type=DIALPEER_INFO_SPEECH
*Dec 26 22:26:31.546: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=9120722
*Dec 26 22:26:31.546: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
*Dec 26 22:26:31.934: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=91207227, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=91207227
*Dec 26 22:26:31.934: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
*Dec 26 22:26:32.602: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=912072277, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=912072277
*Dec 26 22:26:32.606: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
*Dec 26 22:26:33.382: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9120722776, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9120722776
   Result=Success(0) after DP_MATCH_DEST
*Dec 26 22:26:33.386: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=702
*Dec 26 22:26:33.386: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Dec 26 22:26:33.390: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=9120722776, Called Number=9120722776, Peer Info Type=DIALPEER_INFO_SPEECH
*Dec 26 22:26:33.390: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 26 22:26:33.390: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   Calling Number=9120722776, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=702
   Result=SUCCESS(0)
*Dec 26 22:26:33.394: //-1/98A189FD81D3/DPM/dpMatchPeersCore:
*Dec 26 22:26:33.394: //-1/98A189FD81D3/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 26 22:26:33.574: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=91[2-9]......., Called Number=, Voice-Interface=0x0,
*Dec 26 22:26:33.578: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 26 22:26:36.374: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7018$, Called Number=, Voice-Interface=0x0,
*Dec 26 22:26:36.378: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules AttemptER01#
Hi Eric.
Dialed number 9120722776 is matching dialpeer 702 on your VG.
The issue could be your provider that is probably rejecting your call or a wrong rule on youp translation profile SIP_1.
Please share a debug ccsip messeges output to dig more into your problem.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
It look like you are sending wrong calling number to your ITSP.
Please attach these debugs.
debug ccsip messages
debug voip ccapi inout
And your translation pattern.
Manish
Rate all the helpful post.
Translation profile:
voice translation-rule 3
rule 1 /^7../ /2072267262/
voice translation-rule 4
rule 1 /^9\(1....\)/ /\1/
rule 2 /^9207\(...\)/ /\1/
rule 3 /^9\(011.*\)/ /\1/
rule 4 /^9\([2-9]11\)/ /\1/
voice translation-profile SIP_1
translate calling 3
translate called 4
Here is debug ccsip messages:
*Dec 27 14:10:16.598: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:metaswitch@66.55.220.166:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 207.5.178.214:5060;branch=z9hG4bKd77b793048igqgkfd0g1.1
Allow-Events: message-summary, refer, dialog, line-seize, presence, call-info, as-feature-event
Max-Forwards: 69
Call-ID: SDp6vve01-196593d11e4bf68c71f8a4085d7de7d0-c54gcb0
From: ;tag=SDp6vve01-callagent.gwi.net+1+8bfe3a+d3cf6d84
CSeq: 938331054 OPTIONS
Organization: MetaSwitch
Supported: resource-priority, 100rel
Content-Length: 0
Contact:
To:
*Dec 27 14:10:16.606: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To:
GMIT-VOICEROUT166>;tag=F1B5120-18BD
Date: Fri, 27 Dec 2013 14:10:16 GMT
Server: Cisco-SIPGateway/IOS-12.x
Supported: 100rel,resource-priority,replaces,sdp-anat
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Content-Type: application/sdp
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 4484 7548 IN IP4 66.55.220.166
s=SIP Call
c=IN IP4 66.55.220.166
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
ER01#
GMIT-VOICEROUTER01#
*Dec 27 14:10:34.834: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:120722776@callcentric.com:5080 SIP/2.0
Via: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK5795232C
From: "Server Room" <>20722672628@callcentric.com>;tag=F1B9854-8A5
To: <>120722776@callcentric.com>
Date: Fri, 27 Dec 2013 14:10:34 GMT
Call-ID: 7CCFEC9F-6E3711E3-824190AE-21CDDC5B@66.55.220.166
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2066961728-1849102819-2185007278-567139419
User-Agent: Cisco-SIPGateway/IOS-12.x
GMIT-VOICEROUTER01#YE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1388153434
Contact: <20722672628>
Expires: 180
Content-Disposition: session;handling=required
Content-Length: 297
v=0
o=CiscoSystemsSIP-GW-UserAgent 3022 9963 IN IP4 66.55.220.166
s=SIP Call
t=0 0
m=audio 19258 RTP/AVP 18 101 19
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
*Dec 27 14:10:34.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
v: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK5795232C
f: "Server Room" <>20722672628@callcentric.com>;tag=F1B9854-8A5
t: <>120722776@callcentric.com>
i: 7CCFEC9F-6E3711E3-824190AE-21CDDC5B@66.55.220.166
CSeq: 1
GMIT-VOICEROUT01 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="3755ae79fd668c2035ebb90cdc12d030", opaque="", stale=TRUE, algorithm=MD5
l: 0
*Dec 27 14:10:34.914: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:120722776@callcentric.com:5080 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK579619F9
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="17772882353",realm="callcentric.com",uri="sip:120722776@callcentric.com:5080",response="cbac03a76a23b6a35ebbee966c00a577",nonce="3755ae79fd668c2035ebb90cdc12d030",opaque="",algorithm=MD5
Content-Length: 297
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
*Dec 27 14:10:34.990: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Incorrect Authentication
v: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK579619F9
CSeq: 102 INVITE
l: 0
*Dec 27 14:10:35.002: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Here is debug voip ccapi inout:
GMIT-VOICEROUTER01#debug voip ccapi inout
voip ccapi inout debugging is on
GMIT-VOICEROUTER01#
*Dec 27 14:10:55.326: //-1/8912F77B8243/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=7018
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Dec 27 14:10:55.326: //-1/8912F77B8243/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4A4AE7B0, Call Info(
   Calling Number=7018,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20009, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
GMIT-VOICEROUT, Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Dec 27 14:10:55.326: //-1/8912F77B8243/CCAPI/ccCheckClipClir:
   In: Calling Number=7018(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=7018(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Dec 27 14:10:55.326: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 27 14:10:55.326: :cc_get_feature_vsa malloc success
*Dec 27 14:10:55.326:  cc_get_feature_vsa count is 1
*Dec 27 14:10:55.326: :FEATURE_VSA attributes are: feature_name:0,feature_time:1282234808,feature_id:151
*Dec 27 14:10:55.330: //12898/8912F77B8243/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7018(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
*Dec 27 14:10:55.330: //12898/8912F77B8243/CCAPI/cc_process_call_setup_ind:
   Event=0x49A103B8
*Dec 27 14:10:55.330: //12898/8912F77B8243/CCAPI/ccCallSetContext:
   Context=0x4C5A319C
*Dec 27 14:10:55.334: //12898/8912F77B8243/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 12898 with tag 20009 to app "_ManagedAppProcess_Default"
*Dec 27 14:10:55.334: //12898/8912F77B8243/CCAPI/ccCallSetupAck:
   Call Id=12898
*Dec 27 14:10:55.334: //12898/8912F77B8243/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
*Dec 27 14:10:55.334: //12898/8912F77B8243/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=12898
*Dec 27 14:10:55.334: //12898/8912F77B8243/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
*Dec 27 14:10:55.338: //12898/8912F77B8243/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Dec 27 14:10:55.338: //12898/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x3262, digit_event=0x1, enable=TRUE, consume=FALSE)
*Dec 27 14:10:55.338: //12898/8912F77B8243/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=12898
*Dec 27 14:10:55.338: //12898/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4A4AE7B0, callID=0x3262, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Dec 27 14:10:55.338: //12898/8912F77B8243/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x4A4AE7B0, Call Id=12898
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
*Dec 27 14:10:56.650: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=12898, Digit=9, DigitBeginFlags=0x0,
   Rtp Timestamp=0x9D41D0, Rtp Expiration=0x0
*Dec 27 14:10:56.654: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
   Source Call Id=12898, Digit=9, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
*Dec 27 14:10:56.970: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Source Call Id=12898, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x9DBED0, Rtp Expiration=0x0
*Dec 27 14:10:56.974: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
   Source Call Id=12898, Digit=1, Duration=100,
*Dec 27 14:10:57.290: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Source Call Id=12898, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x9E3BD0, Rtp Expiration=0x0
*Dec 27 14:10:57.294: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
   Source Call Id=12898, Digit=2, Duration=100,
*Dec 27 14:10:57.610: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Source Call Id=12898, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0x9EB8D0, Rtp Expiration=0x0
*Dec 27 14:10:57.614: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
   Source Call Id=12898, Digit=0, Duration=100,
*Dec 27 14:10:57.890: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Source Call Id=12898, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0x9F35D0, Rtp Expiration=0x0
*Dec 27 14:10:57.894: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
   Source Call Id=12898, Digit=7, Duration=100,
*Dec 27 14:10:58.162: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x9FB2D0, Rtp Expiration=0x0
*Dec 27 14:10:58.162: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
*Dec 27 14:10:58.314: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xA02FD0, Rtp Expiration=0x0
*Dec 27 14:10:58.314: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
*Dec 27 14:10:58.582: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xA0ACD0, Rtp Expiration=0x0
*Dec 27 14:10:58.582: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
*Dec 27 14:10:58.754: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xA129D0, Rtp Expiration=0x0
*Dec 27 14:10:58.754: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
*Dec 27 14:10:59.022: //12898/8912F77B8243/CCAPI/cc_api_call_digit_begin:
   Source Call Id=12898, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0xA1A6D0, Rtp Expiration=0x0
*Dec 27 14:10:59.022: //12898/8912F77B8243/CCAPI/cc_api_call_digit_end:
   Source Call Id=12898, Digit=6, Duration=100,
*Dec 27 14:10:59.026: //12898/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x3262, digit_event=0x0, enable=FALSE, consume=FALSE)
*Dec 27 14:10:59.026: //12898/8912F77B8243/CCAPI/ccCallReportDigits:
*Dec 27 14:10:59.026: //12898/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4A4AE7B0, callID=0x3262, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Dec 27 14:10:59.026: //12898/8912F77B8243/CCAPI/cc_api_call_report_digits_done:
*Dec 27 14:10:59.026: //12898/8912F77B8243/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*Dec 27 14:10:59.030: //12898/8912F77B8243/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=702, Params=0x4C5A0BDC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Dec 27 14:10:59.030: //12898/8912F77B8243/CCAPI/ccCheckClipClir:
   In: Calling Number=20722672628(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=20722672628(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=91[2-9]......., Called Number=120722776, Digit Strip=FALSE
   Calling Number=20722672628(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=120722776(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Server Room
   Account Number=, Final Destination Flag=FALSE,
   Guid=8912F77B-6E37-11E3-8243-90AE21CDDC5B, Outgoing Dial-peer=702
*Dec 27 14:10:59.030: //12898/8912F77B8243/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=20722672628
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=120722776
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Dec 27 14:10:59.034: //12898/8912F77B8243/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x48C27BD0, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=20722672628,(Calling Name=Server Room)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=120722776(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=702, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Dec 27 14:10:59.034: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 27 14:10:59.034: :cc_get_feature_vsa malloc success
*Dec 27 14:10:59.034:  cc_get_feature_vsa count is 2
*Dec 27 14:10:59.034: :FEATURE_VSA attributes are: feature_name:0,feature_time:1282234584,feature_id:152
*Dec 27 14:10:59.034: //12899/8912F77B8243/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Dec 27 14:10:59.034: //12899/8912F77B8243/CCAPI/ccCallSetContext:
   Context=0x4C5A0B8C
*Dec 27 14:10:59.034: //12898/8912F77B8243/CCAPI/ccSaveDialpeerTag:
*Dec 27 14:10:59.038: //12899/8912F77B8243/CCAPI/cc_api_call_proceeding:
   Interface=0x48C27BD0, Progress Indication=NULL(0)
*Dec 27 14:10:59.270: //12899/8912F77B8243/CCAPI/cc_api_call_disconnected:
   Cause Value=57, Interface=0x48C27BD0, Call Id=12899
   Call Entry(Responsed=TRUE, Cause Value=57, Retry Count=0)
*Dec 27 14:10:59.270: //12898/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Dec 27 14:10:59.270: //12899/8912F77B8243/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=12899
*Dec 27 14:10:59.270: //12899/8912F77B8243/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=57)
   Cause Value=57, Call Entry(Responsed=TRUE, Cause Value=57)
*Dec 27 14:10:59.274: //12899/8912F77B8243/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48C27BD0, Tag=0x0, Call Id=12899,
   Call Entry(Disconnect Cause=57, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Dec 27 14:10:59.274: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 27 14:10:59.274: :cc_free_feature_vsa freeing 4C6D58D0
*Dec 27 14:10:59.274:  vsacount in free is 1
*Dec 27 14:10:59.278: //12898/8912F77B8243/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Dec 27 14:10:59.278: //12898/8912F77B8243/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Dec 27 14:11:02.250: //12898/8912F77B8243/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A4AE7B0, Tag=0x0, Call Id=12898,
*Dec 27 14:11:02.250: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 27 14:11:02.250: :cc_free_feature_vsa freeing 4C6D59B0
*Dec 27 14:11:02.250:  vsacount in free is 0ER01#
Hi Eric.
You are passing incorrect authentication parameters to your provider
"SIP/2.0 403 Incorrect Authentication"
Please verify them with your TSP
Carlo
I understand what you are saying, but my auth parameters are correct.  I can use the softphone Zoiper with the same parameters to make calls with no issue.  Possibly my voice router is sending the authentication incorrectly?
Incorrect authentication may be because you are sending only nine digit uri to ITSP.
Change your translation pattern.
Manish
Please rate all the helpful post.
Hi Eric.
Please share your sip-ua configuration so I can check a possible mismatch with what you are sending to the provider.
Let me know
Carlo
Carlo,
Here it is:
sip-ua
credentials username 17772882353 password 7 06211D721F400418171C realm callcentric.com
authentication username 17772882353 password 7 1535195F572426253A38
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server ipv4:172.16.4.251 expires 3600 port 5060 transport udp
registrar dns:callcentric.com expires 60
sip-server dns:callcentric.com
host-registrar
Understood but I don't know why that is happening.
Hi Eric.
Try to modify your authentication with
authentication username 17772882353 password 7 1535195F572426253A38 real callcentric.com
Carlo
Done, no change.  Still get fast busy.  Here are the debugs:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.12.27 09:47:13 =~=~=~=~=~=~=~=~=~=~=~=
SIP Call messages tracing is enabled
GMIT-VOICEROUTER01#
*Dec 27 14:47:37.994: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK5856ED1
From: "Server Room" <>20722672628@callcentric.com>;tag=F3D848C-123C
Date: Fri, 27 Dec 2013 14:47:37 GMT
Call-ID: A9F5926D-6E3C11E3-82BA90AE-21CDDC5B@66.55.220.166
Min-SE:  1800
Cisco-Guid: 2816683423-1849430499-2192937134-567139419
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1388155657
Expires: 180
Content-Length: 297
v=0
o=CiscoSystemsSIP-GW-UserAgent 7254 8619 IN IP4 66.55.220
GMIT-VOICEROUT.166
s=SIP Call
t=0 0
m=audio 17218 RTP/AVP 18 101 19
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
*Dec 27 14:47:38.070: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK5856ED1
f: "Server Room" <>20722672628@callcentric.com>;tag=F3D848C-123C
i: A9F5926D-6E3C11E3-82BA90AE-21CDDC5B@66.55.220.166
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="eb98ac1092d31d42db624f4d99bcb6aa", opaque="", stale=TRUE, algorithm=MD5
l: 0
*Dec 27 14:47:38.074: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Dec 27 14:47:38.078: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK5857697
Date: Fri, 27 Dec 2013 14:47:38 GMT
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1388155658
Expires: 180
Proxy-Authorization: Digest username="17772882353",realm="callcentric.com",uri="sip:120722776@callcentric.com:5080",response="233ab405b0b8fd83f6dae091be5c3c2d",nonce="eb98ac1092d31d42db624f4d99bcb6aa",opaque="",algorithm=MD5
Content-Length: 297
v=0
o=CiscoSystemsSIP-GW-UserAgent 7254 8619 IN IP4 66.55.220.166
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
*Dec 27 14:47:38.166: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK5857697
CSeq: 102 INVITE
l: 0
*Dec 27 14:47:38.178: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
ER01#
GMIT-VOICEROUTER01#no debug all
All possible debugging has been turned off
GMIT-VOICEROUTER01#
*Dec 27 14:47:52.554: //-1/B2A515B082BC/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=7018
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Dec 27 14:47:52.554: //-1/B2A515B082BC/CCAPI/cc_api_call_setup_ind_common:
*Dec 27 14:47:52.554: //-1/B2A515B082BC/CCAPI/ccCheckClipClir:
*Dec 27 14:47:52.554: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 27 14:47:52.554: :cc_get_feature_vsa malloc success
*Dec 27 14:47:52.554:  cc_get_feature_vsa count is 1
*Dec 27 14:47:52.554: :FEATURE_VSA attributes are: feature_name:0,feature_time:1282039248,feature_id:169
*Dec 27 14:47:52.558: //13097/B2A515B082BC/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Dec 27 14:47:52.558: //13097/B2A515B082BC/CCAPI/cc_process_call_setup_ind:
   Event=0x49A10DC0
*Dec 27 14:47:52.558: //13097/B2A515B082BC/CCAPI/ccCallSetContext:
   Context=0x4C59734C
*Dec 27 14:47:52.562: //13097/B2A515B082BC/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 13097 with tag 20009 to app "_ManagedAppProcess_Default"
*Dec 27 14:47:52.562: //13097/B2A515B082BC/CCAPI/ccCallSetupAck:
   Call Id=13097
*Dec 27 14:47:52.562: //13097/B2A515B082BC/CCAPI/cc_api_set_transfer_info:
*Dec 27 14:47:52.562: //13097/B2A515B082BC/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=13097
*Dec 27 14:47:52.562: //13097/B2A515B082BC/CCAPI/ccSetDigitTimeouts:
*Dec 27 14:47:52.566: //13097/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x3329, digit_event=0x1, enable=TRUE, consume=FALSE)
*Dec 27 14:47:52.566: //13097/B2A515B082BC/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=13097
*Dec 27 14:47:52.566: //13097/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4A4AE7B0, callID=0x3329, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Dec 27 14:47:52.566: //13097/B2A515B082BC/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x4A4AE7B0, Call Id=13097
*Dec 27 14:47:53.078: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13097, Digit=9, DigitBeginFlags=0x0,
   Rtp Timestamp=0xB2DD10, Rtp Expiration=0x0
*Dec 27 14:47:53.082: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
   Source Call Id=13097, Digit=9, Duration=100,
*Dec 27 14:47:53.370: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13097, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0xB35A10, Rtp Expiration=0x0
*Dec 27 14:47:53.370: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
   Source Call Id=13097, Digit=1, Duration=100,
*Dec 27 14:47:53.550: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13097, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0xB3D710, Rtp Expiration=0x0
*Dec 27 14:47:53.550: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
   Source Call Id=13097, Digit=2, Duration=100,
*Dec 27 14:47:53.890: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13097, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0xB45410, Rtp Expiration=0x0
*Dec 27 14:47:53.890: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
   Source Call Id=13097, Digit=0, Duration=100,
*Dec 27 14:47:54.150: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13097, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0xB4D110, Rtp Expiration=0x0
*Dec 27 14:47:54.150: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
   Source Call Id=13097, Digit=7, Duration=100,
*Dec 27 14:47:54.398: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xB54E10, Rtp Expiration=0x0
*Dec 27 14:47:54.402: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
*Dec 27 14:47:54.538: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xB5CB10, Rtp Expiration=0x0
*Dec 27 14:47:54.542: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
*Dec 27 14:47:54.798: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xB64810, Rtp Expiration=0x0
*Dec 27 14:47:54.802: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
*Dec 27 14:47:54.970: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xB6C510, Rtp Expiration=0x0
*Dec 27 14:47:54.970: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
*Dec 27 14:47:55.262: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13097, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0xB74210, Rtp Expiration=0x0
*Dec 27 14:47:55.262: //13097/B2A515B082BC/CCAPI/cc_api_call_digit_end:
   Source Call Id=13097, Digit=6, Duration=100,
*Dec 27 14:47:55.262: //13097/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x3329, digit_event=0x0, enable=FALSE, consume=FALSE)
*Dec 27 14:47:55.262: //13097/B2A515B082BC/CCAPI/ccCallReportDigits:
*Dec 27 14:47:55.262: //13097/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4A4AE7B0, callID=0x3329, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Dec 27 14:47:55.262: //13097/B2A515B082BC/CCAPI/cc_api_call_report_digits_done:
*Dec 27 14:47:55.266: //13097/B2A515B082BC/CCAPI/ccCallProceeding:
*Dec 27 14:47:55.270: //13097/B2A515B082BC/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=702, Params=0x4C59E5CC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Dec 27 14:47:55.270: //13097/B2A515B082BC/CCAPI/ccCheckClipClir:
   Guid=B2A515B0-6E3C-11E3-82BC-90AE21CDDC5B, Outgoing Dial-peer=702
*Dec 27 14:47:55.270: //13097/B2A515B082BC/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=120722776
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Dec 27 14:47:55.270: //13097/B2A515B082BC/CCAPI/ccIFCallSetupRequestPrivate:
*Dec 27 14:47:55.270: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 27 14:47:55.270: :cc_get_feature_vsa malloc success
*Dec 27 14:47:55.270:  cc_get_feature_vsa count is 2
*Dec 27 14:47:55.270: :FEATURE_VSA attributes are: feature_name:0,feature_time:1282039024,feature_id:170
*Dec 27 14:47:55.274: //13098/B2A515B082BC/CCAPI/ccIFCallSetupRequestPrivate:
*Dec 27 14:47:55.274: //13098/B2A515B082BC/CCAPI/ccCallSetContext:
   Context=0x4C59E57C
*Dec 27 14:47:55.274: //13097/B2A515B082BC/CCAPI/ccSaveDialpeerTag:
*Dec 27 14:47:55.278: //13098/B2A515B082BC/CCAPI/cc_api_call_proceeding:
*Dec 27 14:47:55.462: //13098/B2A515B082BC/CCAPI/cc_api_call_disconnected:
   Cause Value=57, Interface=0x48C27BD0, Call Id=13098
*Dec 27 14:47:55.462: //13097/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
*Dec 27 14:47:55.462: //13098/B2A515B082BC/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=13098
*Dec 27 14:47:55.462: //13098/B2A515B082BC/CCAPI/ccCallDisconnect:
*Dec 27 14:47:55.466: //13098/B2A515B082BC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48C27BD0, Tag=0x0, Call Id=13098,
*Dec 27 14:47:55.466: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 27 14:47:55.466: :cc_free_feature_vsa freeing 4C6A5CE8
*Dec 27 14:47:55.466:  vsacount in free is 1
*Dec 27 14:47:55.470: //13097/B2A515B082BC/CCAPI/ccCallDisconnect:
*Dec 27 14:47:55.470: //13097/B2A515B082BC/CCAPI/cc_api_get_transfer_info:
*Dec 27 14:47:57.182: //13097/B2A515B082BC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A4AE7B0, Tag=0x0, Call Id=13097,
*Dec 27 14:47:57.182: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 27 14:47:57.182: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:*Dec 27 14:47:57.182: :cc_free_feature_vsa freeing 4C6A5DC8
*Dec 27 14:47:57.182:  vsacount in free is 0ER01#
GMIT-VOICEROUTER01#
Hi Eric.
Please add this line under sip-ua configuration
calling-info sip-to-pstn number set 17772882353
After this, pleae resend the dubug.
Carlo
Commands added, same result.  Here are the debugs:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.12.27 10:03:27 =~=~=~=~=~=~=~=~=~=~=~=
GMIT-VOICEROUTER01#
*Dec 27 15:03:23.670: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.5.178.214:5060;branch=z9hG4bKta6ajd004o7h9ksue681.1
Max-Forwards: 69
Call-ID: SD4vm1d01-eff4e0c52a3d5e24fefdee74e2b495d1-c54gcb0
From: ;tag=SD4vm1d01-callagent.gwi.net+1+16910e+6d33b999
CSeq: 86979570 OPTIONS
Content-Length: 0
Contact:
To:
*Dec 27 15:03:23.678: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To:
GMIT-VOICEROUT66>;tag=F4BF29C-11C7
Date: Fri, 27 Dec 2013 15:03:23 GMT
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 5590 4665 IN IP4 66.55.220.166
s=SIP Call
t=0 0
*Dec 27 15:03:23.738: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK58B3CBE
From: "Server Room" <>20722672628@callcentric.com>;tag=F4BF2DC-BB9
Call-ID: DDA17D8E-6E3E11E3-82FC90AE-21CDDC5B@66.55.220.166
Min-SE:  1800
Cisco-Guid: 3687148285-1849561571-2197262510-567139419
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1388156603
Expires: 180
Content-Length: 297
v=0
o=CiscoSystemsSIP-GW-UserAgent 7145 4459 IN IP4 66.55.220.166
s=SIP Call
t=0 0
m=audio 17376 RTP/AVP 18 101 19
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
*Dec 27 15:03:23.818: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK58B3CBE
f: "Server Room" <>20722672628@callcentric.com>;tag=F4BF2DC-BB9
i: DDA17D8E-6E3E11E3-82FC90AE-21CDDC5B@66.55.220.166
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="a74bfad4aaccf45e2d69641f61dfee48", opaque="", stale=TRUE, algorithm=MD5
l: 0
*Dec 27 15:03:23.826: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK58B4824
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="17772882353",realm="callcentric.com",uri="sip:120722776@callcentric.com:5080",response="2862cd7a6e3782f9146231f61bc371e6",nonce="a74bfad4aaccf45e2d69641f61dfee48",opaque="",algorithm=MD5
Content-Length: 297
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
*Dec 27 15:03:23.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 66.55.220.166:5060;branch=z9hG4bK58B4824
CSeq: 102 INVITE
l: 0
*Dec 27 15:03:23.918: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
ER01#
GMIT-VOICEROUTER01#
*Dec 27 15:03:40.914: //-1/E7E9531982FE/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=7018
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Dec 27 15:03:40.914: //-1/E7E9531982FE/CCAPI/cc_api_call_setup_ind_common:
*Dec 27 15:03:40.914: //-1/E7E9531982FE/CCAPI/ccCheckClipClir:
*Dec 27 15:03:40.914: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 27 15:03:40.914: :cc_get_feature_vsa malloc success
*Dec 27 15:03:40.914:  cc_get_feature_vsa count is 1
*Dec 27 15:03:40.914: :FEATURE_VSA attributes are: feature_name:0,feature_time:1282371864,feature_id:202
*Dec 27 15:03:40.914: //13190/E7E9531982FE/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Dec 27 15:03:40.918: //13190/E7E9531982FE/CCAPI/cc_process_call_setup_ind:
   Event=0x49A103B8
*Dec 27 15:03:40.918: //13190/E7E9531982FE/CCAPI/ccCallSetContext:
   Context=0x4C58EE14
   >>>>CCAPI handed cid 13190 with tag 20009 to app "_ManagedAppProcess_Default"
*Dec 27 15:03:40.922: //13190/E7E9531982FE/CCAPI/ccCallSetupAck:
   Call Id=13190
*Dec 27 15:03:40.922: //13190/E7E9531982FE/CCAPI/cc_api_set_transfer_info:
*Dec 27 15:03:40.922: //13190/E7E9531982FE/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=13190
*Dec 27 15:03:40.926: //13190/E7E9531982FE/CCAPI/ccSetDigitTimeouts:
*Dec 27 15:03:40.926: //13190/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x3386, digit_event=0x1, enable=TRUE, consume=FALSE)
*Dec 27 15:03:40.926: //13190/E7E9531982FE/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=13190
*Dec 27 15:03:40.926: //13190/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4A4AE7B0, callID=0x3386, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Dec 27 15:03:40.926: //13190/E7E9531982FE/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x4A4AE7B0, Call Id=13190
*Dec 27 15:03:41.330: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13190, Digit=9, DigitBeginFlags=0x0,
   Rtp Timestamp=0xC39650, Rtp Expiration=0x0
*Dec 27 15:03:41.330: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
   Source Call Id=13190, Digit=9, Duration=100,
*Dec 27 15:03:41.710: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13190, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0xC41350, Rtp Expiration=0x0
*Dec 27 15:03:41.710: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
   Source Call Id=13190, Digit=1, Duration=100,
*Dec 27 15:03:41.930: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13190, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0xC49050, Rtp Expiration=0x0
*Dec 27 15:03:41.930: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
   Source Call Id=13190, Digit=2, Duration=100,
*Dec 27 15:03:42.238: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13190, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0xC50D50, Rtp Expiration=0x0
*Dec 27 15:03:42.238: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
   Source Call Id=13190, Digit=0, Duration=100,
*Dec 27 15:03:42.478: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13190, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0xC58A50, Rtp Expiration=0x0
*Dec 27 15:03:42.478: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
   Source Call Id=13190, Digit=7, Duration=100,
*Dec 27 15:03:42.738: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xC60750, Rtp Expiration=0x0
*Dec 27 15:03:42.738: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
*Dec 27 15:03:42.890: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xC68450, Rtp Expiration=0x0
*Dec 27 15:03:42.890: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
*Dec 27 15:03:43.110: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xC70150, Rtp Expiration=0x0
*Dec 27 15:03:43.110: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
*Dec 27 15:03:43.290: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xC77E50, Rtp Expiration=0x0
*Dec 27 15:03:43.290: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
*Dec 27 15:03:43.698: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_begin:
   Source Call Id=13190, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0xC7FB50, Rtp Expiration=0x0
*Dec 27 15:03:43.698: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
   Source Call Id=13190, Digit=6, Duration=100,
*Dec 27 15:03:43.702: //13190/E7E9531982FE/CCAPI/cc_api_call_digit_end:
*Dec 27 15:03:43.702: //13190/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x3386, digit_event=0x0, enable=FALSE, consume=FALSE)
*Dec 27 15:03:43.702: //13190/E7E9531982FE/CCAPI/ccCallReportDigits:
*Dec 27 15:03:43.702: //13190/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4A4AE7B0, callID=0x3386, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Dec 27 15:03:43.702: //13190/E7E9531982FE/CCAPI/cc_api_call_report_digits_done:
*Dec 27 15:03:43.706: //13190/E7E9531982FE/CCAPI/ccCallProceeding:
*Dec 27 15:03:43.710: //13190/E7E9531982FE/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=702, Params=0x4C59ACB4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Dec 27 15:03:43.710: //13190/E7E9531982FE/CCAPI/ccCheckClipClir:
   Guid=E7E95319-6E3E-11E3-82FE-90AE21CDDC5B, Outgoing Dial-peer=702
*Dec 27 15:03:43.710: //13190/E7E9531982FE/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=120722776
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Dec 27 15:03:43.710: //13190/E7E9531982FE/CCAPI/ccIFCallSetupRequestPrivate:
*Dec 27 15:03:43.710: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 27 15:03:43.710: :cc_get_feature_vsa malloc success
*Dec 27 15:03:43.710:  cc_get_feature_vsa count is 2
*Dec 27 15:03:43.710: :FEATURE_VSA attributes are: feature_name:0,feature_time:1282371640,feature_id:203
*Dec 27 15:03:43.710: //13191/E7E9531982FE/CCAPI/ccIFCallSetupRequestPrivate:
*Dec 27 15:03:43.710: //13191/E7E9531982FE/CCAPI/ccCallSetContext:
   Context=0x4C59AC64
*Dec 27 15:03:43.714: //13190/E7E9531982FE/CCAPI/ccSaveDialpeerTag:
*Dec 27 15:03:43.714: //13191/E7E9531982FE/CCAPI/cc_api_call_proceeding:
*Dec 27 15:03:43.890: //13191/E7E9531982FE/CCAPI/cc_api_call_disconnected:
   Cause Value=57, Interface=0x48C27BD0, Call Id=13191
*Dec 27 15:03:43.890: //13190/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
*Dec 27 15:03:43.890: //13191/E7E9531982FE/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=13191
*Dec 27 15:03:43.890: //13191/E7E9531982FE/CCAPI/ccCallDisconnect:
*Dec 27 15:03:43.894: //13191/E7E9531982FE/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48C27BD0, Tag=0x0, Call Id=13191,
*Dec 27 15:03:43.894: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 27 15:03:43.894: :cc_free_feature_vsa freeing 4C6F7030
*Dec 27 15:03:43.894:  vsacount in free is 1
*Dec 27 15:03:43.898: //13190/E7E9531982FE/CCAPI/ccCallDisconnect:
*Dec 27 15:03:43.898: //13190/E7E9531982FE/CCAPI/cc_api_get_transfer_info:
*Dec 27 15:03:45.918: //13190/E7E9531982FE/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A4AE7B0, Tag=0x0, Call Id=13190,
*Dec 27 15:03:45.918: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 27 15:03:45.918: :cc_free_feature_vsa freeing 4C6F7110
*Dec 27 15:03:45.918:  vsacount in free is 0ER01#
GMIT-VOICEROUTER01#
Can you test one more change.
rule 1 /^9\(91....\)/ /\1/
And then dial 99120722776
Manish
Re: Dial-Peer matches but fails to call out
Hi Eric
Can you please share your config?
With command I suggested you we should see an output like this:
Sent:
From: "Server Room" <>17772882353@callcentric.com >
Carlo
Here is the whole config:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.12.27 10:28:54 =~=~=~=~=~=~=~=~=~=~=~=
h sh config
Using 9543 out of 245752 bytes
version 12.4
service password-encryption
hostname GMIT-VOICEROUTER01
boot-start-marker
boot system flash c2800nm-adventerprisek9_ivs_li-mz.124-24.T6.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone boston -4
clock summer-time boston recurring
dot11 syslog
no ip source-route
--More--         ip cef
ip dhcp pool Voice
   network 172.16.2.0 255.255.255.0
   default-router 172.16.2.1
   dns-server 8.8.8.8 8.8.4.4
   option 150 ip 172.16.2.1
ip domain name domain
ip name-server 8.8.8.8
ip name-server 209.28.47.62
no ipv6 cef
voice service voip
--More--          allow-connections h323 to h323
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol cisco
sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
--More--         !
translate calling 3
translate called 4
voice-card 0
--More--         !
username xxx privilege 15 password 7 1511021F0725
archive
log config
  hidekeys
interface Loopback0
description MANAGEMENT
ip address 172.16.254.4 255.255.255.255
interface FastEthernet0/0
ip address 66.55.220.166 255.255.255.252
ip nat outside
--More--          ip virtual-reassembly
duplex full
speed 100
interface Service-Engine0/0
ip address 172.16.4.250 255.255.255.0
service-module ip address 172.16.4.251 255.255.255.0
service-module ip default-gateway 172.16.4.251
interface FastEthernet0/1
no ip address
duplex full
speed 100
interface FastEthernet0/1.10
encapsulation dot1Q 10 native
ip address 192.168.5.2 255.255.255.0
ip nat inside
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 172.16.3.1 255.255.255.0 secondary
--More--          ip address 172.16.2.1 255.255.255.0
ip nat inside
router eigrp 100
redistribute static
passive-interface default
no passive-interface Service-Engine0/0
no passive-interface FastEthernet0/1
no passive-interface Loopback0
network 172.16.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 66.55.220.165
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:gui
ip nat inside source list 101 interface FastEthernet0/0 overload
--More--         access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 101 permit ip 172.16.0.0 0.0.255.255 any
nls resp-timeout 1
cpd cr-id 1
snmp-server community marvelous RO
tftp-server flash:OS79XX.TXT
tftp-server flash:P00307010200.bin
tftp-server flash:P00307010200.loads
tftp-server flash:P00307010200.sb2
tftp-server flash:P00307010200.sbn
tftp-server flash:TERM41.DEFAULT.loads
tftp-server flash:Jar41.2-9-1-45.sbn
tftp-server flash:cnu41.2-7-5-50.sbn
tftp-server flash:CVM41.2-0-1-45.sbn
control-plane
--More--         !
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
ring number 2
connection plar opx 7001
description Connected to 207-764-1834
caller-id enable type 1
voice-port 0/1/1
ring number 2
connection plar opx 7002
shutdown
dial-peer voice 3 voip
description *** Voicemail Extension 7000 - Do not delete! ***
--More--          destination-pattern 7000
session target ipv4:172.16.4.251
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2000 voip
shutdown
destination-pattern 200.
codec g711ulaw
--More--          description SIP Trunk - Outgoing 3-Digit Calls
preference 1
voice-class codec 1
dtmf-relay rtp-nte
preference 1
destination-pattern 91[2-9].........
dtmf-relay rtp-nte
--More--          preference 1
destination-pattern 9[2-9].........
voice-class codec 1
no vad
sip-ua
credentials username 17772882353 password 7 0728331F1D0714040519 realm callcentric.com
authentication username 17772882353 password 7 00230155575506071D2A realm callcentric.com
no remote-party-id
retry invite 2
retry register 10
timers connect 100
host-registrar
--More--         !
gatekeeper
shutdown
telephony-service
max-ephones 42
max-dn 100
ip source-address 172.16.3.1 port 2000
auto assign 1 to 10
system message Greenmark IT
url services http://phone-xml.berbee.com/menu.xml
load 7960-7940 P00307010200
voicemail 7000
mwi relay
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name admin secret 5 $1$UfDD$ffCmnvpfJnT5NpJBgnDfk1
dn-webedit
transfer-system full-blind
transfer-pattern 1001
--More--          night-service weekday 17:00 07:30
night-service weekend 23:59 23:59
create cnf-files version-stamp 7960 Oct 13 2012 19:30:35
ephone-dn  1  dual-line
number 7010 no-reg both
description Eric Warren
name Eric
call-forward busy 7000
call-forward noan 7000 timeout 10
mwi-type both
mwi sip
ephone-dn  2  dual-line
number 7011 no-reg both
description Jenn Edgecomb
name Jenn
mwi-type both
mwi sip
--More--         !
ephone-dn  3  dual-line
number 7012 no-reg both
description Charly Chandler
name Charly
mwi-type both
mwi sip
ephone-dn  4  dual-line
number 7013 no-reg both
description Tim Levesque
name Tim
mwi-type both
mwi sip
ephone-dn  5  dual-line
--More--          number 7014 no-reg both
description Michelle Warren
name Michelle
mwi-type both
mwi sip
ephone-dn  6  dual-line
number 7015 no-reg both
description Jessica Grigsby
name Jessica
mwi-type both
mwi sip
ephone-dn  7  dual-line
number 7016 no-reg both
description Jon Kimball
name Jonathan
--More--          call-forward busy 7000
mwi-type both
mwi sip
ephone-dn  8  dual-line
number 7017 no-reg both
description Tech Bench
name Tech Bench
mwi-type both
ephone-dn  9  dual-line
number 7018 no-reg both
description Server Room
name Server Room
mwi-type both
ephone-dn  10
--More--         !
ephone-dn  11
number 8000
mwi on
ephone-dn  12
number 8001
mwi off
ephone-dn  13  dual-line
number 7001
label 764-1834
name 764-1834
huntstop channel
ephone-dn  14  dual-line
number 7002
label 764-1835
name 764-1835
--More--          huntstop channel
ephone-dn  15
call-forward night-service 2000
night-service bell
ephone-dn  81
number 2072267262 no-reg primary
label 2072267262
description Callcentric SIP Trunk DID 1
ephone-dn  82
number 17772882353 no-reg primary
label 17772882353
description Callcentric SIP Trunk Public
ephone-dn  91
number 2075545122 no-reg primary
label 554-5122
--More--          description SIP Trunk 1
ephone  1
device-security-mode none
mac-address 0019.E778.4559
type 7960
button  1:1 2m2 3m3 4m4
button  5:13 6:14
ephone  2
mac-address 000E.D76D.F67C
type 7960
button  1:2 5:13 6:14
ephone  3
mac-address 000E.D72E.46E0
--More--          type 7960
button  1:3 5:13 6:14
ephone  4
mac-address 000E.D76E.0192
type 7960
button  1:4 5:13 6:14
ephone  5
mac-address 000E.8461.296E
type 7960
button  1:5 5:13 6:14
ephone  6
--More--          mac-address 000E.D76E.019F
type 7960
button  1:6 2:91 5:13 6:14
ephone  7
mac-address 000D.BD40.7F37
type 7960
button  1:7
ephone  8
mac-address 0013.C472.847D
type 7960
button  1:8
ephone  9
--More--          device-security-mode none
mac-address 0007.5012.1B41
type 7960
button  1:9 6o81,82
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 194
password 7 00071A150754
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
logging synchronous
login local
transport input telnet ssh
--More--         line vty 5 15
logging synchronous
login local
scheduler allocate 20000 1000
end
GMIT-VOICEROUTER01#
Hi Eric,
Just for knowledge , did you get this resolved?
Manish
Yes.  My CME was sending out the authentication string 207xxxxxxx@x.x.x.x,  where xxxxxxx was the DID I was calling from.  My ITSP was expecting @x.x.x.x as that username authenticates all the DID's that I have with them.
We used this to rewrite the authentication string on outgoing calls:
voice class sip-profiles 1
request INVITE sip-header From modify "<>" "" where XXXX = is username
Then we applied that to the outgoing dial peer and we wer able to make outbound calls.
435
