dial-peer matching/best practice
noname2010
we have a call manager cluster with a H323 gateway, DID range is 200X, telco sending 4 digits to the PRI
we also have a non-DID range, 201X
on the h323 gateway, we have below dial-peer configured
dial-peer voice 2000 voip
destination-pattern 200.
session target IPv4:CM_IP
codec
blah
dial-peer voice 1000 pots
incoming called .
direct-inward-dial
port 0/0:23
dial-peer voice 100 pots
destination-pattern 9.T
port 0/0:23
when PSTN caller called one of the DID, 2001, the incoming dial-peer is 1000, and outgoing dial-peer is 2000, this is clear
when one of the DID making PSTN call, I would guess the incoming dial-peer is 2000, and outgoing dial-peer is 100
how about the non-DID making PSTN call? which incoming dial-peer would be matched? default dial-peer 0? what is the dial-peer 0 default config?
if matching the default dial-peer 0, as best practice, do we need add a specific dial-peer like
dial-peer voice 50 voip
incoming called .
thanks
Aaron Harrison
I would concur with your first two statements.
For the final one, the call would match peer 0, and get default settings. This process (and peer 0) are described here:
http://www.buycisco.info/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml#topic1
You can do a debug voip dialpeer to see what is being matched.
You could fix this lots of ways:
1) Adjust the destination-pattern on peer 2000 to be 20[01]. - yes, calls should never get routed out via it, but it is used as a match for inbounds calls
2) Add incomining called-number . to the 2000 peer, so all VoIP calls hit that.
3) Add another dial peer same as 2000, but with 201. matched and same settings.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
Thanks Aaron for your reply.
for the non-DID, here is my opinion regarding your reply
add destination-pattern would not make sense, because it confused with DID range
add incoming called . to 2000 dialpeer would case confusion as well for troubleshooting
I prefer the 3rd option to have a separate dial-peer with incoming called . only, not destination-pattern
what is your opinion?
thanks
As I say, all should work, so it's whatever you are most comfortable with.
I like option 3 as well. Just proves that the first thing you think of isn't always the most sensible :-)
Aaron
