Dial Peer matching on IOS
Here is the scenario ,  I have following dial-peer
Dial-peer  voice 1000 pots
Destination-pattern 9........ ( 8 dots)
Port 0/0/0:15
Dial-peer voice 1001 pots
Destination-pattern 9T
Port 0/0/0:15
When i dial 9 1111 1111 11 then call is matched to dial-peer 1000 and send out only 1111 1111 and drop the last two 11.  Why this number does not match the dial-peer  1001 ? Is there any setting to be configured on the voice gateway in order to wait all the number to be matched and route it out on the dial-peer 1001 ?
  • IP Telephony
Hall of Fame Super Gold
Re: Dial Peer matching on IOS
That is working as designed. As soon you enter 9 and any 8 digits, DP 1000 is matched because it's the only DP configured exactly to do that.
You have a case of overlap. If you want some numbers to be matched right away, and others by timeout, you can disambiguate the patterns using digit matches. If you can't do that (unlikely), you have to use a single DP, configured with Timeout.
Green
Well put by Paolo (+5)
Here is an additional link to help you
learn about dial peers
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Alex
Regards, Alex. Please rate useful posts.
200
