dial-peer matching
I cannot figure out dial-peer matching.  I'm trying to point a phone number at a new place.  Unfortunately, the wildcard match for all of our numbers keeps matching.  I don't understand why.  I thought the longest match wins.
dial-peer voice 2001 voip
tone ringback alert-no-PI
preference 5
destination-pattern 432555....
progress_ind setup enable 3
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target ipv4:10.10.0.10
dtmf-relay rtp-nte
ip qos dscp cs4 signaling
no vad
dial-peer voice 2007 voip
preference 1
destination-pattern 4325551212
voice-class codec 1
session target ipv4:10.29.1.41
dtmf-relay rtp-nte
no vad
2001 keeps matching.  What gives?
1 REPLY
Re: dial-peer matching
What is the inbound dial peer that is matching? What called number is the router seeing? You can run "debug voip dialpeer" to see these.
Brandon
203
