dial-peer problem
We are turning up a new PRI on a shared tenant phone system. This is our first H.323 gateway. We have a very large number of DID's on the system. We currently have the following patterns (which is not working):
dial-peer voice 1 voip
preference 1
destination-pattern .......
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.10
incoming called-number .
dtmf-relay h245-signal h245-alphanumeric
no vad
dial-peer voice 2 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.11
no vad
dial-peer voice 10 pots
destination-pattern .T
direct-inward-dial
port 1/0:23
forward-digits all
The problem is that when a call comes in, the POTS dial peer is picking it up and sending the call back out the PRI.
How can we configure the dial peers so that anything coming from the VoIP side gets directed out the POTS peers and anything from the POTS side gets directed to the VoIP peers?
1 ACCEPTED SOLUTION
Re: dial-peer problem
Hi Jordan,
You can using corlists and do something like this:
dial-peer cor custom
name a
name b
dial-peer cor list a
member a
dial-peer cor list b
member b
session target ipv4:1.1.1.1
incoing called-number .
corlist outgoing a
corlist incoming b
direct-inward-dial
corlist outgoing b
corlist incoming a
You may want to come up with something easier to manage. Possibly set up prefixes that you use for routing, etc.
Example of that would be marking inbound voip calls with the prefix 1#, and then setting the destination-pattern on the pots dial peers to be 1#.T.
The config would look like this:
translation-rule 1
rule 1 /\(.*\)/ /1#\1/
translation-profile 1
translate called 1
dial-peer voice 1(and/or 2)
translation-profile incoming 1
destination-pattern 1#.T
A couple options to wrap your mind around. You may find it easier to have the voip systems prepend a certain prefix before it gets to this gateway as well.
hth,
nick
Hall of Fame Super Gold
How the number thta you gave to tenants looks like ?
We have various, non-contiguous blocks. And as we add new tenants, we may port individual numbers onto our network. So, they can vary greatly.
Seems like you would have a distinct advantage in using MGCP in this case then.
Hi Jordan,
name a
name b
member a
member b
corlist outgoing a
corlist incoming b
direct-inward-dial
corlist outgoing b
corlist incoming a
translation-rule 1
translate called 1
hth,
nick
183
