Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Dial-peer problem
Hi, I have a 2811 voice-gateway and I have a problem with dial-peer.
I have these two dial-peer betweens others:
dial-peer voice 2 pots
description Long Distance
destination-pattern ..[2-6].......
direct-inward-dial
port 0/0/0:15
forward-digits all
prefix 021
dial-peer voice 3 pots
description Mobile calls
destination-pattern [7-9].......
direct-inward-dial
port 0/3/0
forward-digits all
When I call the number 8339751223 in CallManager, it sends the full number ( 8339751223 ) to voice-gateway and the gateway matches with the dial-peer 3.
Why, if I sent ten digits and not eight?
When I launch the show dialplan number 8339751223 command, the result is the dial-peer 3 first than dial-peer 2.
Does anyone can help me?
tks
Bronze
Re: Dial-peer problem
Are your dial peers all up? Can you send the output of 'show dial-peer voice summary' ?
HTH, Avner.
Hi, all those dial-peer they are UP as it proceeds below:
Sh dial-peer voice summ
2 pots up up 021 ..[2-6]....... 0 up 0/0/0:15
3 pots up up [7-9]....... 0 up 0/3/0
TKS
Bronze
ok, did wanted to see the full output of the command to make sure there is no other things involved, but never mind.
Next step would be to run 'debug voip dialpeer' and make a call from call manager to the problematic number. Then we might be able to figure out what is going on.
Let me know, Avner.
Hi, it follows the sh debug below when dialing starting from my extension for I number him/it external 8330442700
Aug 22 21:08:55.153: //-1/0093F9E2C508/DPM/dpAssociateIncomingPeerCore:
Calling Number=8265, Called Number=8330442700, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=100
Aug 22 21:08:55.157: //-1/0093F9E2C508/DPM/dpMatchPeersCore:
Calling Number=, Called Number=8330442700, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8330442700
Result=Success(0) after DP_MATCH_DEST
Aug 22 21:08:55.157: //-1/0093F9E2C508/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=100
2: Dial-peer Tag=3
3: Dial-peer Tag=2
dial-peer voice 100 voip
description CCM Calls
destination-pattern 8[2-3]..
session target ipv4:192.168.1.5
dtmf-relay h245-alphanumeric
codec g711alaw
no vad
direct-inward-dial
port 0/0/0:15
forward-digits all
prefix 021
direct-inward-dial
port 0/3/0
forward-digits all
Bronze
The debug doesn't have the outbound dial peer match in it, I'm interested in the part that came after what you pasted in. Can you provide with more info?
thanks, Avner.
Avner, good morning!
I Enabled the " debug voip dialpeer all ", more information appeared, see if it can help!
When giving match, should not he await all the digits before deciding the route?
I enclosed a file txt with the debug, because it surpasses the amount of characters allowed in Post.
TKS
Bronze
Hi Leonardo,
Thanks for the debugs. He is supposed to match according to the longest match, but something is happening.
Can you send the output of 'debug voip ccapi inout' (it will be much longer). Also the full gateway configuration might help (take out the passwords and ip addresses. This way I can also simulate your config in my lab and see if I get the same results.
Regards, Avner.
Hi, Avner.
I have perceived that there is like a rotary between dial-peers 2 and 3.
You can see this in that attached file.
Let me know your opinion.
Best regards
Leonardo
Bronze
It might be, I'll have to look at the output of 'show run' and of 'debug voip ccapi inout' to be sure.
Thanks, Avner.
Hi, Avner.
I tried something and the solution worked fine.
I put the "$" in the end of destination-pattern.
See below:
destination-pattern ..[2-6].......$
direct-inward-dial
port 0/0/0:15
forward-digits all
prefix 021
destination-pattern [7-9].......$
direct-inward-dial
port 0/3/0
forward-digits all
Now, it matches the entire number.
What do you think. Worked fine with me.
tks
Leonardo
Bronze
If it works, then it is good.
My personal preference is to have a digit for outbound calls (9 for example) and send that digit to the h.323 gateway. The gateway then strips the prefix from that called number.
Thanks for letting us know, point given :)
152
