Dial Peer Question VGW to CUCM
I have 4 cisco voice gateways.
2x 3845's
2x 3945's
I'm looking to put in 8 call manager's.  4 that are active and 4 that are backup.
My question is, do I need my dial peers to be exactly the same on each voice gateway?
For instance here are two dial-peers on one of my voice gateways that point to two different call managers.
dial-peer voice 50 voip
description Inbound calls send to CCM
destination-pattern [2-7]....
progress_ind setup enable 3
voice-class codec 100
voice-class h323 1
session target ipv4:10.74.13.2
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 51 voip
preference 1
voice-class h323 1
session target ipv4:10.73.13.3
no vad
Would I need to do the following on each voice gateway for true redundancy?
preference 1
voice-class h323 1
no vad
preference 2
voice-class h323 1
session target ipv4:10.74.13.3
no vad
dial-peer voice 52 voip
preference 3
voice-class h323 1
session target ipv4:10.74.13.4
no vad
dial-peer voice 53 voip
preference 4
voice-class h323 1
session target ipv4:10.74.13.5
no vad
etc etc........................................
its depends upon what you need..need more information about design. And you need to set your routepattern in CUCM for call routing......
is this centeralized ddeployement ?
Hall of Fame Super Silver
Your dial-peer destinations need to match the 3 CUCM servers that are assigned to CM Group used by the device pool that is assigned to the H323 Gateway on CUCM, simple as that.
HTH,
Chris
So I'm planning on using the following:
PUB - rudua-cucmp001
CMG1
sub1 - d-cucm001
sub3 - p-cucm003   ----> VGW3845-1
sub5 - d-cucm003
CMG2
sub2 - d-cucm002
sub4 - p-cucm004  ---> VGW3845-2
sub6 - d-cucm004
CMG3
sub7 - p-cucm001
sub5 - d-cucm003  ---> VGW3945-1
sub3 - p-cucm003
CMG4
sub8 - p-cucm002
sub6 - d-cucm004 ---> VGW3945-2
sub4 - p-cucm004
TFTP/MOH
sub9 - d-cucm005
sub10 - p-cucm005
So what would happen with VGW3845-1?  Wouldn't that mean all my call manager's associated to that VGW would have call routing issues?
You will need to ensure that the dial-peers on that GW point to these 3 servers. Call will not be accepted unless the CM Group used by the GW configuration references common servers.
For outbound now you have more flexibility with CUCM 8.5+ as you can use "Run on All Nodes" configuration on the Route Lists.
HTH, please rate all useful posts!
Chris
So I guess with my configruation there really isn't redudancy in case of single router failing correct?
I don't know what your setup is as in one post you are showing hostnames and the other you have IPs.  I am not your DNS to resolve it :-)
But, I provided you the logic of how it works, should be easy to come up with conclusions.
HTH,  glad of providing you with assistance!!!
Chris
I have the same deployment. I would like to reduce the number of dial-peers to 1 Dial-peer. Is that possible if I use server groups in the dial-peer that directs inbound calls to CUCM.?
Doc:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/dialpeer/configuration/xe-3s/vd-xe-3s-book/multiple-server-groups.html
Yes, but that is brand new feature on brand new IOS, so you may need to upgrade your IOS.  Keep in mind that feature works only for voip dial peers and not pots (just an FYI).
HTH,
Chris
531
