Community Member
Dial Peer Question
Hi Netpros.
I have two faxes in the same office which are connected to different ATA boxes. The faxes have 4 digit extensiton numbers fax 1 = 5286 fax 2= 5288
I have a H.323 gateway with the following dial peer config and translation pattern
dial-peer voice 9 pots
tone ringback alert-no-PI
description *** Outgoign POTS PEER ***
destination-pattern 9T
progress_ind setup enable 3
progress_ind progress enable 8
port 0/0/0:15
dial-peer voice 1 pots
description *** Incoming POTS peer ***
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 5201 voip
preference 1
destination-pattern 52..
voice-class codec 1
voice-class h323 1
session target ipv4:10.118.2.10
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 5202 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.118.8.10
no vad
voice-port 0/0/0:15
translate calling 10
translate called 1
cptone GB
translation-rule 10
Rule 0 ^. 90
translation-rule 1
Rule 0 755... 5
Now the problem is this - when I send a fax directly from 5286 to 5288 it works (please note I only use the 4 digit extension to dial) however when I try and dial the full national number 01**5 755888 it doesn't get accepted into the fax memory. The fax rings but nothing happens
below is an output of debug isdn q931 - can anyone help? thanks.
wifvoip#
May  6 07:31:12.314: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xA793
wifvoip#
May  6 07:31:19.510: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xA793
May  6 07:31:19.514: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x2793
wifvoip#
May  6 07:31:44.811: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 5286
May  6 07:31:44.811: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 01xx5755288
May  6 07:31:44.811: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x2794
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0081, '5286'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '01xx5755288'
May  6 07:31:45.007: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xA794
May  6 07:31:45.091: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0002
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Progress Ind i = 0x8583 - Origination address is non-ISDN
wifvoip#
        Calling Party Number i = 0x2181, '1xx5755286'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, '755288'
                Plan:ISDN, Type:Unknown
May  6 07:31:45.103: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8002
May  6 07:31:45.279: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8002
May  6 07:31:45.391: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xA794
wifvoip#
May  6 07:31:48.043: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8002
May  6 07:31:48.107: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0002
May  6 07:31:48.155: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xA794
May  6 07:31:48.155: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x2794
wifvoip#
May  6 07:32:19.080: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x2793
        Cause i = 0x8090 - Normal call clearing
May  6 07:32:19.240: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xA793
May  6 07:32:19.240: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x2793
wifvoip#
May  6 07:32:28.216: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8002
May  6 07:32:28.376: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0002
May  6 07:32:28.380: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8002
May  6 07:32:28.400: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xA794
        Progress Ind i = 0x8288 - In-band info or appropriate now available
May  6 07:32:28.404: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xA715
1 REPLY
Community Member
Re: Dial Peer Question
Hi Rod,
Please, tell us your enviroment configuration:
Are you using Call Manager?
Which router model? IOS?
Thank you
199
