Community Member
dial peer question
Hello
if incoming is a fax  i want to route the fax server , if it  is a call i want to route to faxserver
How can i do that please help
dial-peer voice 201 voip
 preference 9
 destination-pattern ..
 voice-class codec 1
 session target ipv4:CUCM IP ADDRESS
 incoming called-number .
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 302 voip
 destination-pattern 3859
 session protocol sipv2
 session target ipv4:FAXSERVERIP:5062
 dtmf-relay rtp-nte
 codec g711ulaw
 fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
 no vad
Hall of Fame Super Silver
You have the right concept
You have the right concept here, you can route the call to desired destination based on called number which is what "destination-pattern" does for you.  One thing you need to consider is also the incoming dial-peer (which in your example is dial peer 201 as it has incoming called-number .) so for faxing to work properly you should apply fax settings (fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco) to this dial-peer as well unless you have it defined globally.
Chris
Community Member
HiThanks .  'destination
Thanks .  'destination-pattern .. ' ,Does it mean any two digit number ? .
In my case  whether it is  call or fax dial peer 302 is matching ? Any ideas
Yes, this means that routing
Yes, this means that routing is based only on 2 digits, which does not sound right (never seen 2 digits received from telco).  Since the other dial-peer uses 4 digits you should change the dial-peer 201 to "destination-pattern ...."
To find out for sure perform debug on the gateway to see what telco send you, if this is a PRI circuit use "debug isdn q931", if SIP "debug ccsip messages", if POTS "debug voice ccapi inout".
Chris
Community Member
 Yes sending only two digits,
Yes sending only two digits, What are the problems may arise telco sending only two digits ?.
 The destination-pattern was wrong, It must be  'destination-pattern 38'.
And it is an E1 line.
Please provide the debugs, as
Please provide the debugs, as I have never seen telco sending you only 2 digits, plus your other dial-peer matches on 4. Unless these arrive on different trunks it would be impossible to receive different digit lengths.
Chris
Community Member
Thanks chrisBelow is the
Thanks chris
Below is the output of  'debug isdn q931'
Sep  8 04:57:25.406: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x00EC
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '22253184'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x81, '99'
                Plan:ISDN, Type:Unknown
Sep  8 04:57:25.422: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x80EC
Sep  8 04:57:25.462: ISDN Se1/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x80EC
Sep  8 04:57:25.522: ISDN Se1/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x00EC
Sep  8 04:57:25.522: %ISDN-6-CONNECT: Interface Serial1/0:30 is now connected to 22253184 N/A
Sep  8 04:57:36.419: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x00EC
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Sep  8 04:57:36.419: %ISDN-6-DISCONNECT: Interface Serial1/0:30  disconnected from 22253184, call lasted 10 seconds
Sep  8 04:57:36.419: ISDN Se1/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xA3
Sep  8 04:57:36.439: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x80EC
Sep  8 04:57:36.487: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x00EC
Thanks again
You indeed are receiving only
You indeed are receiving only 2 digits per  Called Party Number i = 0x81, '99' , so please define the destination pattern using the 2 digits you want to use.
Community Member
Thanks chrisdial-peer voice
Thanks chris
 destination-pattern 99
 dtmf-relay rtp-nte
 codec g711ulaw
 no va
After changing the destination pattern  two digit( destination-pattern 99)
Any number which starts from '99XXXXXX' disconnects after 6 seconds , and the called party cannot hear anything , Meaning the the outgoing call matches the  dial-peer voice 302 voip and routing the call to the  faxserver ( this works also a pbx ) and fax server sends again to vg or cucm
Any solution to this ?
96
