Silver
dial-peer question
dial-peer voice 11 voip
voice-class h323 1
incoming called-number 1#
tech-prefix 1#
dtmf-relay h245-signal
fax-relay ecm disable
fax rate 14400
no vad
Is this dial-peer working- as there is no session target or port1/1 .....
many thanks
Hall of Fame Super Gold
Re: dial-peer question
This is a valid incoming voip DP.
It is not a valid outgoing voip DP.
See what is the difference:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080147524.shtml
Understanding the Operational Status of Dial Peers on Cisco IOS Platforms
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a008010e6d1.shtml
easy way to tell is typing
show dial-peer voice summary
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
397
