dial-peer routing based on number of connections
Anyone knows a way in IOS to route based on number of calls. I want to send all incoming SIP calls to one SIP destinations, and once there are 10 calls, route to the second destination. If there's not anything native in IOS, I'd like to do this possibly with EEM (but not TCL).
1 ACCEPTED SOLUTION
Green
May be someting like this :-
dial-peer voice 100 voip
preference 1
desc ** TEST 1 **
destination-pattern 1234
incoming called-number .
Session protocol sipv2
session target ipv4:192.168.1.100
Dtmf-relay rtp-nte
codec g711ulaw
max-conn 10
ip qos dscp ef media
ip qos dscp cs3 sig
no vad
dial-peer voice 200 voip
preference 2
desc ** TEST 2**
session target ipv4:192.168.1.200
Dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs3 sig
no vad
The 1st 10 calls will route tp 192.168.1.100 as it is preference 1 after that it will use 192.168.1.200
Alex
Regards, Alex. Please rate useful posts.
Green
preference 1
desc ** TEST 1 **
Dtmf-relay rtp-nte
codec g711ulaw
max-conn 10
ip qos dscp cs3 sig
no vad
preference 2
desc ** TEST 2**
Dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs3 sig
no vad
Alex
I'll have to give that a try, thanks!
288
