04-21-2008 10:40 AM - edited 03-15-2019 10:11 AM
Hi. Hi i have CCM6.1 and gateway 2821 with vic2/4fxo. On gateway i have configuration(
voice-port 0/3/0
connection plar opx 401
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
dial-peer voice 2000 voip
destination-pattern ...
session target ipv4:10.10.18.5
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2001 voip
destination-pattern 401
incoming called-number .
codec g711ulaw
no vad
dial-peer voice 101 pots
preference 1
destination-pattern 9T
port 0/3/0
dial-peer voice 102 pots
preference 2
port 0/3/1
dial-peer voice 103 pots
preference 3
port 0/3/2
dial-peer voice 104 pots
preference 4
port 0/3/3
When i call whith pbx on port 0/3/x the phone with DN 401 don't Ring. You can help me fix it?
10.10.18.5 - ip CCM.
04-21-2008 11:12 AM
Is the router configured as h.323 gw in the CM?
You can also configure a trunk group for the fxo ports. This will let you use a single outgoing DP.
04-21-2008 11:19 AM
Yes. Router configured as h323 gw in ccm.
Outgoing call work.
