Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Dial Peer session target for 2 CCM 4.1 servers.
We have a Subscriber and a Publisher CCM 4.1 servers. I have set up my Dial Peers to use both of them. Basically I want to have it fall over to the other server and if one server is down for any reason and have it fall over automatically. I have an PRI coming into a Cisco 2851 router with IOS 12.4(9)T. On Call Manager I have defined it as an H323 gateway.
Here is my current config:
dial-peer voice 9802 voip
destination-pattern 235....
modem passthrough nse codec g711ulaw
session target ipv4:192.168.225.4
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
no vad
dial-peer voice 2261 voip
destination-pattern 226....
codec g711ulaw
fax rate disable
no vad
dial-peer voice 2262 voip
session target ipv4:192.168.225.5
codec g711ulaw
fax rate disable
no vad
dial-peer voice 9803 voip
codec g711ulaw
fax rate disable
no vad
1 ACCEPTED SOLUTION
Re: Dial Peer session target for 2 CCM 4.1 servers.
take a look at this doc
H.323 Gateway Dial-Peer Configuration for Cisco CallManager Server Redundancy
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080094852.shtml
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Thanks I think that is what I needed!
216
