Community Member
dial-peer voice pots doesn't strip prefix digits.
I try to separate calls for different E1 ports:
dial-peer voice 10 pots
huntstop
destination-pattern 111.+
port 1/0:15
dial-peer voice 20 pots
destination-pattern 222.+
incoming called-number .T
port 1/1:15
And I want the prefixes 111 and 222 will be deleted when call reaches the outbound POTS dial peer. But it not happen. Do somebody know why?
So as DNIS number come to device the same number goes from outbound POTS dial peer.
debug voip ccapi inout
*Mar 23 20:31:44.951: //-1/30F4380BE637/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=95.215.0.5
   ----- ccCallInfo IE subfields -----
   cisco-ani=8123749844
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=11178123367575
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1
*Mar 23 20:31:44.951: //-1/30F4380BE637/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x883EAF5C, Call Info(
   Calling Number=8123749844(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=11178123367575(TON=Unknown, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=50, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=14
*Mar 23 20:31:44.955: //-1/30F4380BE637/CCAPI/ccCheckClipClir:
   In: Calling Number=8123749844(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=8123749844(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
*Mar 23 20:31:44.955: //14/30F4380BE637/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=8123749844(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=11178123367575(TON=Unknown, NPI=ISDN))
*Mar 23 20:31:44.959: //14/30F4380BE637/CCAPI/cc_process_call_setup_ind:
   Event=0x8873ED70
*Mar 23 20:31:44.967: //14/30F4380BE637/CCAPI/ccCallSetContext:
   Context=0x888EE554
*Mar 23 20:31:44.967: //14/30F4380BE637/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 14 with tag 50 to app "_ManagedAppProcess_Default"
*Mar 23 20:31:44.971: //14/30F4380BE637/CCAPI/ccCallProceeding:
*Mar 23 20:31:44.975: //14/30F4380BE637/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=10, Params=0x888EF204, Progress Indication=NULL(0)
*Mar 23 20:31:44.975: //14/30F4380BE637/CCAPI/ccCheckClipClir:
*Mar 23 20:31:44.979: //14/30F4380BE637/CCAPI/ccCallSetupRequest:
   Destination Pattern=111.+, Called Number=11178123367575, Digit Strip=TRUE
   Redirect Number=, Display Info=
   Account Number=95.215.0.5, Final Destination Flag=TRUE,
   Guid=30F4380B-B36A-F94F-E637-000046464636, Outgoing Dial-peer=10
*Mar 23 20:31:44.979: //14/30F4380BE637/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=11178123367575
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 23 20:31:44.983: //14/30F4380BE637/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x8477CB48, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=8123749844(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=11178123367575(TON=Unknown, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Mar 23 20:31:44.983: //15/30F4380BE637/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Mar 23 20:31:44.983: //15/30F4380BE637/CCAPI/ccCallSetContext:
   Context=0x888EF1B4
*Mar 23 20:31:44.983: //14/30F4380BE637/CCAPI/ccSaveDialpeerTag:
*Mar 23 20:31:45.092: //15/30F4380BE637/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x8477CB48, Call Id=15
*Mar 23 20:31:45.096: //15/30F4380BE637/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=21, Retry Count=0)
*Mar 23 20:31:45.096: //15/30F4380BE637/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=15
*Mar 23 20:31:45.096: //15/30F4380BE637/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=21)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
*Mar 23 20:31:45.100: //15/30F4380BE637/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Mar 23 20:31:45.104: //15/30F4380BE637/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8477CB48, Tag=0x0, Call Id=15,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Mar 23 20:31:45.108: //14/30F4380BE637/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Mar 23 20:31:45.112: //14/30F4380BE637/CCAPI/ccCallDisconnect:
*Mar 23 20:31:45.112: //14/30F4380BE637/CCAPI/cc_api_get_transfer_info:
*Mar 23 20:31:45.120: //14/30F4380BE637/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x883EAF5C, Tag=0x0, Call Id=14,
*Mar 23 20:34:45.127: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
Router#sh ver
Load for five secs: 1%/0%; one minute: 0%; five minutes: 0%
No time source, *20:51:47.330 UTC Sat Mar 23 2002
Cisco IOS Software, C2600 Software (C2600-IPVOICEK9-M), Version 12.4(23b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sun 02-Aug-09 19:54 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 25 minutes
System returned to ROM by reload
System image file is "flash:c2600-ipvoicek9-mz.124-23b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2651XM (MPC860P) processor (revision 3.1) with 221184K/40960K bytes of memory.
Processor board ID JAE0823KMFA
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
43 Serial interfaces
4 Channelized E1/PRI ports
1 ATM/Voice AIM
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Router#sh run
Load for five secs: 0%/0%; one minute: 0%; five minutes: 0%
No time source, *20:52:30.714 UTC Sat Mar 23 2002
Building configuration...
Current configuration : 3438 bytes
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
logging queue-limit 100000
logging buffered 1024000 debugging
logging rate-limit 10000
no logging console
enable secret 5 $1$DGq4$fNPWEp4IpEwFw1eCSbKm8/
no aaa new-model
memory-size iomem 15
no network-clock-participate slot 1
no network-clock-participate wic 1
voice-card 0
dspfarm
no local-bypass
voice-card 1
dspfarm
ip cef
ip name-server 85.235.192.2
ip name-server 85.235.193.2
isdn switch-type primary-5ess
voice call carrier capacity active
voice service pots
voice service voip
h323
  h225 timeout tcp call-idle never
  h225 timeout setup 30
  session transport udp
  h245 tunnel disable
  h245 caps mode restricted
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
username admin privilege 15 password 7 060506324F41
controller E1 0/0
shutdown
framing NO-CRC4
controller E1 0/1
framing NO-CRC4
pri-group timeslots 1-31
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-5,16
controller E1 1/1
framing NO-CRC4
interface FastEthernet0/0
ip address XXX.XXX.XXX.XXX 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.99.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
no cdp enable
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
interface Serial1/1:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX
ip http server
no ip http secure-server
control-plane
voice-port 0/1:15
shutdown
voice-port 1/0:15
voice-port 1/1:15
huntstop
port 1/0:15
port 1/1:15
dial-peer voice 30 pots
destination-pattern 333.T
port 0/1:15
dial-peer voice 50 voip
destination-pattern .T
voice-class codec 1
session target ipv4:192.168.99.2
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 60 voip
preference 1
voice-class codec 1
session target ipv4:217.174.106.50
no vad
dial-peer voice 70 voip
preference 2
voice-class codec 1
session target ipv4:46.4.114.175
no vad
dial-peer voice 80 voip
preference 3
shutdown
voice-class codec 1
session target ipv4:95.215.0.5
no vad
line con 0
line aux 0
line vty 0 4
login local
exec prompt timestamp
transport input telnet
end
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Take 'debug isdn q931' only.
Re: dial-peer voice pots doesn't strip prefix digits.
Configure
destination-pattern 111...
with as many dots as digits following '111'. If it can be a variable lenght number, then place the minium dots, followed by T
Community Member
Hi, Paolo.
I tried different variants: dots, forward-digits, translation-ruls. Nothing help.
I have configured as you said, result the same.
huntstop
destination-pattern 111...........
port 1/0:15
*Mar 23 21:22:15.852: //-1/30F4980A603A/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=11178123367575
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 23 21:22:15.856: //-1/30F4980A603A/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=16
*Mar 23 21:22:15.856: //-1/30F4980A603A/CCAPI/ccCheckClipClir:
*Mar 23 21:22:15.860: //16/30F4980A603A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Mar 23 21:22:15.860: //16/30F4980A603A/CCAPI/cc_process_call_setup_ind:
   Event=0x8873ED70
*Mar 23 21:22:15.868: //16/30F4980A603A/CCAPI/ccCallSetContext:
   Context=0x888EFE14
*Mar 23 21:22:15.868: //16/30F4980A603A/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 16 with tag 50 to app "_ManagedAppProcess_Default"
*Mar 23 21:22:15.872: //16/30F4980A603A/CCAPI/ccCallProceeding:
*Mar 23 21:22:15.876: //16/30F4980A603A/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=10, Params=0x888F0AC4, Progress Indication=NULL(0)
*Mar 23 21:22:15.880: //16/30F4980A603A/CCAPI/ccCheckClipClir:
*Mar 23 21:22:15.880: //16/30F4980A603A/CCAPI/ccCallSetupRequest:
   Destination Pattern=111..........., Called Number=11178123367575, Digit Strip=TRUE
   Guid=30F4980A-8A76-F94F-603A-000046464636, Outgoing Dial-peer=10
*Mar 23 21:22:15.880: //16/30F4980A603A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=11178123367575
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 23 21:22:15.884: //16/30F4980A603A/CCAPI/ccIFCallSetupRequestPrivate:
*Mar 23 21:22:15.884: //17/30F4980A603A/CCAPI/ccIFCallSetupRequestPrivate:
*Mar 23 21:22:15.888: //17/30F4980A603A/CCAPI/ccCallSetContext:
   Context=0x888F0A74
*Mar 23 21:22:15.888: //16/30F4980A603A/CCAPI/ccSaveDialpeerTag:
*Mar 23 21:22:16.000: //17/30F4980A603A/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x8477CB48, Call Id=17
*Mar 23 21:22:16.004: //17/30F4980A603A/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=17
*Mar 23 21:22:16.004: //17/30F4980A603A/CCAPI/ccCallDisconnect:
*Mar 23 21:22:16.004: //17/30F4980A603A/CCAPI/cc_api_get_transfer_info:
*Mar 23 21:22:16.012: //17/30F4980A603A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8477CB48, Tag=0x0, Call Id=17,
*Mar 23 21:22:16.016: //16/30F4980A603A/CCAPI/ccCallDisconnect:
*Mar 23 21:22:16.020: //16/30F4980A603A/CCAPI/ccCallDisconnect:
*Mar 23 21:22:16.020: //16/30F4980A603A/CCAPI/cc_api_get_transfer_info:
*Mar 23 21:22:16.024: //16/30F4980A603A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x883EAF5C, Tag=0x0, Call Id=16,
*Mar 23 21:22:16.028: //16/30F4980A603A/CCAPI/cc_api_call_disconnect_done:
*Mar 23 21:22:21.926: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (77.37.179.84)
Community Member
Thx! With this debug I see that number is changed.
*Mar 23 23:13:00.439: ISDN Se1/0:15 Q931: pak_private_number: Invalid type/plan 0x0 0x1 may be overriden; sw-type 3
*Mar 23 23:13:00.447: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x3 is 0x2 0x1, Called num 3367575
*Mar 23 23:13:00.447: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0082
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Calling Party Number i = 0xA1, '8123749844'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '3367575'
*Mar 23 23:13:00.519: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8082
        Cause i = 0x8095 - Call rejected
*Mar 23 23:13:00.527: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0082
*Mar 23 23:14:16.355: ISDN Se1/0:15 Q931: pak_private_number: Invalid type/plan 0x0 0x1 may be overriden; sw-type 3
*Mar 23 23:14:16.359: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x3 is 0x2 0x1, Called num 78123367575
*Mar 23 23:14:16.363: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0083
        Sending Complete
                Standard = CCITT
        Called Party Number i = 0xA1, '78123367575'
*Mar 23 23:14:16.415: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8083
*Mar 23 23:14:16.423: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0083
Green
Can you confirm you ISDN switch type selection.
You are using
no ip address
encapsulation hdlc
This for connection in the US and I would have thought for T1 not E1
primary-5ess
AT&T 5ESS switch type
If you are in Europe New Zealoand or Asia
You would normally use primary-net5 for E1 PRI
primary-net5
European, New Zealand and Asia ISDN PRI switches (covers the Euro-ISDN E-DSS1 signaling system and is ETSI-compliant)
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Community Member
Hi Alex,
Yes, I know about primary-5ess and primary-net5. But ISDN provider recommended to use this type of ISDN switch.
ISDN Serial1/0:15 interface
        dsl 1, interface ISDN Switchtype = primary-5ess
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0x8000001F
    Number of L2 Discards = 0, L2 Session ID = 1
Ok I will check.
Community Member
The primary-net5 is also working. But how it can influence to dial-peer translation?
        dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Number of L2 Discards = 0, L2 Session ID = 4
Telco is rejecting the call. Show them the ISDN trace and ask why. If they insist that is router fault, invite them on your premises to place calls using their test equipment.
1463
