Dial peer voice question
Is it possible to route a call based on it's ANI(calling number)? I know I can manipulate the digits, but that's not what I am looking for. As an example, I get a call from 555, I want it routed to specific extension or voice port regardless of the called number. Thanks.
1 REPLY
Hall of Fame Super Gold
Re: Dial peer voice question
Hi, this done quite easily when you've h.323 or sip to connect the GW, using-answer-address and translation-profile under the incoming DP, but if you're using MGCP I hope someone else can suggest something as I' unable to help with that.
115
