Dial-Peer Voice x Voip
How do you does with dial-peers voip to ccm servers? In the cluster with 5 servers, you create 5 dial-peers voip (incoming) to each servers, or there is another way to do?
Re: Dial-Peer Voice x Voip
Yes, use the same dial-peer changing the session target and the preference.
Yes, I known
I want to known if there is another way... similiar to trunkgroup....
no other way, one dial-peer per CUCM server with higher preference
java
if this helps, please rate
java
www.cisco.com/go/pdi
134
