dial-peer voip
i have two sites in every Site uc560 device ipsec between two sites enabled i have problem with dialing from  one site to another
no call incoming no call outgoing
voice-lan (10.1.1.0/24)----------UC560 -------iNTERNET--------------UC560------------VOICE lan (10.1.2.0/24)
but if you  made all phones register  in  one UC560 all phones working Well
note that dial-peer configure well
please advise
thanks
dial-peer voip
Can you please attach the configuration of both UC560?
Thx
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Re:dial-peer voip
Check if all the ports related to voice are open or not.
When you say no outgoing incoming not working, what is the exact behavior....
125
