Dial Peer
huntlee
On my customer VG, i currently have a situation where my IP Phone will be calling 032804000, and it has been translated to 4000 at VG
dial-peer voice 101 voip
destination-pattern 4000
voice-class codec 99
session target ipv4:10.133.140.10
dtmf-relay rtp-nte digit-drop h245-alphanumeric
voice translation-rule 300
rule 1 /32804000/ /4000/
rule 2 /032804000/ /4000/
However, i'm getting this message on VG debug:
*Apr 3 2009 13:18:39.593 tok: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0112
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0081, '9900'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '4000'
*Apr 3 2009 13:18:39.657 tok: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8112
*Apr 3 2009 13:18:39.661 tok: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8112
Cause i = 0x8281 - Unallocated/unassigned number
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Apr 3 2009 13:18:39.661 tok: ISDN Se0/0/0:23 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8055
*Apr 3 2009 13:18:42.141 tok: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x0112
*Apr 3 2009 13:18:42.173 tok: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8112
JTOIPTVGVR01#
Cheers,
Hunt
Hi Hunt,
You'll need to include more information.
Where is the translation profile applied?
How is the call being sent to the gateway?
Why is the gateway sending this 4000 number out the PSTN instead of the voip dial peer?
What is the call flow here?
-nick
Nick,
IP phone (032804000) towards VG, VG will translate 032804000 back to 4000, then send the call back to a CTI Port in CallManager.
Phone > VG > CTI Port
So i don't want the call to get to PSTN, but i do need the call to get out from CallManager before sending it back in.
THere are 2 translation profile. One is for incoming calls and out is outbound.
dial-peer voice 5 pots
translation-profile outgoing MainLine
destination-pattern 032804000
direct-inward-dial
port 0/0/0:23
voice translation-profile MainLine
translate called 300
As for inbound back in
voice translation-profile pstn
translate calling 200
translate called 100
dial-peer voice 1 pots
translation-profile incoming pstn
incoming called-number .
direct-inward-dial
Alright, this doesn't really make any sense.
You would first need this command to enable IPIPGW:
voice service voip
allow h323-to-h323
And your incoming pots dial peer is never being hit because this isn't going to the PSTN. It will also not hit your PSTN because it is also sending to PSTN.
You would need an incoming dial peer that would translate the number to 4000.
voice translation-profile voip-loop
dial-peer voice 1 voip
codec g711ulaw
no vad
translation-profile incoming voip-loop
hth,
nick
The 4000 is the *Final number* that i want the gateway to the call *inbound* back to Callmanager CTI port
