Dial-peer
Hi everyone!
Does dial-peer requires a DSP channel?
Best Regards,
Aleksei
Everyone's tags (1)
1 ACCEPTED SOLUTION
Blue
Dial-peer
No Dial-peer configuration will not use DSP channels.
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Dial-peer
Ronak Patel
VIP Super Bronze
Dial-peer
Just to add to Ronak's response:
The POTS-facing ports (PRI, BRI, FXO/FXS, E&M, etc) require DSPs to convert the analog or digital TDM audio into RTP packets. So, the dial-peer itself doesn't but any POTS interfaces it references does. This is not the case with VoIP dial-peers unless you need to do transcoding between codecs.
332
