03-19-2009 04:38 AM - edited 03-15-2019 04:57 PM
Hi I had two nice and simple dial peers working on two E1 lines.I used the preference command so that 1 would act as a backup. see below
dial-peer voice 1 pots
description local calls to isdn30
translation-profile incoming ddi2
preference 1
destination-pattern 0.T
incoming called-number .
direct-inward-dial
port 0/2/0:15
dial-peer voice 2 pots
description calls to backup isdn
translation-profile incoming incomingddi
preference 2
incoming called-number 201....
direct-inward-dial
port 0/3/0:15
My problems started when my customer wanted to send 0800 number out on the backup line. I removed the two simple peers above and I expanded my dial peers and most outgoing calls started failing. It seems my dial peers are not matching. I attach the config that caused my problems because it easier to see. Take a look and tell me if you see why i cant Dial 0.07xxxxxxxx for example the call fails when i get to 0.07.
regards colin
03-19-2009 12:07 PM
My guess is that your dial peer 4 is too short of a pattern. If you add a T to the destination pattern you might see a different result.
-nick
03-20-2009 05:05 AM
thanks for your reply but dial peer 4 is for dialled numbers 1XX and works, my problem is with numbers 01XXXXXXXX to 07XXXXXXXX like dial peer 5.
regards
colin
03-20-2009 06:25 AM
Could be that because you are using POTS, it will match on the 0.07... only only send out the ...... Any match on a POTS dial-peer will result in that actual matches number not being sent to line- add Forward ( the number of digits you need ) ???
03-20-2009 08:18 AM
the peer is never matched as soon as i dial and get to 007 the call fails no digits are sent.
regards
colin
03-20-2009 08:41 AM
Do a DNA on CCM to confirm the route, GW?
03-20-2009 09:19 AM
Try doing a 'show dialplan number [number you are trying to dial]' and see what peers it thinks it wants to match
