Dial-peers
miket
Level 5
Level 5
I have a small issues, I have several t1's coming into a gateway and I am using cme as srst and bacd as a backup solution. The issue I am having is trying to get several nummbers inbound ie xxx-xxx-1000, xxx-xxx-3050 to transform to a single four digit number so that bacd will kick off..
SO i need several 10 digit inbound to translate to a single four digit like 1000. Any ideas.. I am trying with several pots and a voip dial peers
Help maybe I have just over thought it
Brandon Buffin
One option is to use a translation rule to accomplish this, such as:
voice translation-rule 1
rule 1 /1112221000/ /1000/
rule 2 /1112223050/ /1000/
voice translation-profile profile1
translate called 1
dial-peer voice 1 pots
translation-profile incoming profile1
The translation profile could also be applied to the incoming voice port, such as:
voice-port 0/1/0:23
Hope this helps. If so, please rate the post.
Brandon
Brandon Thanks for the quick reply. I will try this and let you know.
I had done this but I created a voip dial peer that pointed to BACD when maybe I should have put the bacd on the pots
Thanks again.. I really needed someones confirmation you know how it is
