Community Member
Dial Plan 3845
All,
Does anyone knows a good link about testing Dial plan, in a 3845 ISR, for PRI circuits. Or how to create some sort of expect script, or TCL scripting?
Thanks in advance for your help.
Maddox
Hall of Fame Super Gold
Re: Dial Plan 3845
Sorry, you you are confident with your configuration, no script to test would be necessary. What is worring you ?
Re: Dial Plan 3845
I'm not sure exactly what you're looking for, but if you are looking for the ability to test the PRI, try using the command at the gateway "csim start #". This will allow you dial directly from the router, but keep in mind you will need a dialpeer to match what you are trying to dial for testing.
109
