Dial-plan analysis tool?
Is anyone aware of a tool, made by Cisco, or more likely a 3rd party, that allows an admin to analyze pattern usage in the CUCM?
Specifically, I'm looking to get stats on how often dial patterns and translation patterns are used, as part of an effort to streamline the clean up of the dial plan on one of our clusters.
Thanks in advance!
-Tyson
  • IP Telephony
Everyone's tags (1)
CUCM only provides DNA to see
CUCM only provides DNA to see how the call is routed, and CAR for call analysis.
java
if this helps, please rate
www.cisco.com/go/pdi
Right. I'm looking for some
Right. I'm looking for some kind of reporting tool that could parse the CDR logs and organize them in terms of how often the patterns have been used.
52
