Dial Plan problem
I have a problem implementing my dial plan on CUCM 8.6.
I have a translation pattern 049.1XXX (Predot) for internal calls . When i try to call an external number 0491509352 i receive a message from CUCM saying thet the call cannot be completed and the call is not routed to the gateway. I know it's normal because there is no extension 1509 on CUCM.
How can i resolve this problem without adding any digit?
Thank you in advance
Everyone's tags (3)
1 ACCEPTED SOLUTION
Blue
Dial Plan problem
HI
Please de select Translation Pattern Configuration. This will resolve your issue.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Dial Plan problem
Do you have route pattern for this number 0491509352?
Ronak Patel
Dial Plan problem
Yes of course 04XXXXXXXX and the CSS can reach this pattern
Dial Plan problem
Hi Youssef,
Still a little unclear as to what are your requirements, can you trace the call flow something like this
ip phone-->> TP-->> CUCM-->> Gw etc... and let us know what you are looking to achieve.
Niket
Dial Plan problem
i have an internal extensions 1000 , 1001 ... 1010 in Germany Partition.
Ip phones on other partitions (usa, france etc...) shoul call 04910XX to reach this phones. that's why i created a translation pattern 049.1XXX to reach them from other regions.
At the same time , i want to call a PSTN number : 0491509352 that cannot be routed because it matches the translation pattern and not the route pattern 04XXXXXXXX .
I don't want to add an additional digit .
Blue
Dial Plan problem
HI
Ronak Patel
Rate helpful posts.
Dial Plan problem
Thanks Ronak,
That did the trick!!
regards
423
