Community Member
Dial Plan UK Upgrade - DB error failure.
Database connection failed An Error Occurred: 28000
This is the message we are getting after trying to install the 1.1.7 dial plan file. The file itself uploaded and verified correctly without any problems.
1 REPLY
Anonymous
N/A
Re: Dial Plan UK Upgrade - DB error failure.
The error message indicates that the correct file for the dial plan for the callmanager are not used. kindly verify the filename for the callmanager .
120
