Dial special characters as prefix "*" and "#" in CME 7.1
I'm looking how to set a CME in order to dial to PSTN  with * or # before digits
e.g  in order to dial  to local call to pstn  CME's user  should dial  *  as prefix and then the last 8 digits   and then  the discard * and route the call to digital
or analog trunk.
I know in CM server is possible but I haven´t seen  any example with CME.
If I set the following  dial-peer  how can I remove the * in ordet to make the call goes through ??
regards
dial-peer voice 91 pots
corlist outgoing local
description Local Calls
destination-pattern *[1-9].......
direct-inward-dial
port 0/2/0:1
forward-digits 8
1 ACCEPTED SOLUTION
Blue
These characters on standard touch-tone dial pads  can be used anywhere in the pattern. They can be used as the leading  character (for example, *650).
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dp_confg.html
Your configuration is correct. Since it is matching the destination-pattern * will be removed automatically, because exact match digits are removed while dialing out from POTS dialpeer.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Ronak Patel
Hi Ronak,
Thanks for  your answer. Yoou are right, it works . I have already tried.
regards
406
