Dialed number analyser
Hi Can any body tell me where to find the dialed number analyser in CCM ver 6.1 . In ccm ver 4 it is a plugin , we can install it, But ccm ver 6.1 i did not find in plugin. Pls let me knwo
Gem
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Dialed number analyser
Hi Gem,
Dialed Number Analyzer installs as a feature service on Cisco Unified Communications Manager.
Activating Dialed Number Analyzer Service
After Dialed Number Analyzer installs as a service, it starts automatically. You can confirm that the service is started by checking the tool status.
You can activate and deactivate Dialed Number Analyzer service by using Cisco Unified Communications Manager Serviceability after you access it by using the appropriate URL. Use the following procedure to activate the service.
Procedure
Step 1 Access Cisco Unified Communications Manager Serviceability.
Step 2 Choose Tools > Service Activation.
The Service Activation window displays.
Step 3 Select Cisco Dialed Number Analyzer from the Unified CMServices list and click Save.
Note If the service is already activated, the Activation Status will display as Activated.
Step 4 The service gets activated and the Activation Status column displays the status as Activated.
Logging On
This section describes the procedure to log in to Dialed Number Analyzer from a remote server.
Procedure
Step 1 To access DNA, go to Cisco Unified Communications Manager Serviceability and choose Tools > Dial Number Analyzer.
You can also use the following URL:
https:///dna
where specifies the node name or IP address on which Dialed Number Analyzer is installed.
The Enter Network Password dialog displays.
Step 2 In the User Name field, enter a valid user ID.
Use Unified CMAdministrator as the user ID.
Step 3 In the Password field, enter the password that corresponds to the Unified CMAdministrator login ID for that machine.
Step 4 Click OK.
From this good doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dna/6_0_1/dnaacc.html
Hope this helps!
Rob
Hi Gem,
Procedure
Logging On
Procedure
https:///dna
Step 4 Click OK.
From this good doc;
Hope this helps!
Rob
Hi Rob. You are always great in helping others with good explanation.Keep up the work.
It solved my doubts. I rated ur post 5.
Thanks once again
Gem
Hi Gem,
You are most welcome my friend! Glad to be of some small help here :)
Cheers!
Rob
564
