Community Member
Dialing long numbers over ISDN BRI
[Reposting this since it hasn't shown up in 4 hours... hope it doesn't create a double post]
Does ISDN (I'm using basic-net3 switchtype) or CCME have a limitation of 20 digits on called-number digit strings passed to the CO/exchange?
I have a problem where my telco (Telstra) requires me to dial a convoluted sequence of digits to enable call-forward for particular numbers in my indial range. It looks as though CCME is only forwarding the first 20 digits to the BRI.
For simplicity to start with, I've been trying to get call-forward immediate to work, which has the following number sequence (i.e. this must be sent to CO):
* 21 callfwd-dest * * * numtobeforwarded #
where in the example below, I want to forward number 90001030 to 0400100200.
Here's the Q.931 debug:
Feb 9 01:09:40.622: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 90001030
Feb 9 01:09:40.626: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num *210400100200***90001030#
Feb 9 01:09:40.626: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x39
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '90001030'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '*210400100200***9000'
Feb 9 01:09:40.798: ISDN BR0/0/0 Q931: RX <- STATUS pd = 8 callref = 0xB9
Cause i = 0x82E470 - Invalid information element contents
Call State i = 0x01
Feb 9 01:09:40.818: ISDN BR0/0/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0xB9
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8288 - In-band info or appropriate now available
Feb 9 01:09:40.822: ISDN BR0/0/0 Q931: TX -> INFORMATION pd = 8 callref = 0x39
Sending Complete
Called Party Number i = 0x80, '0840#'
Feb 9 01:09:40.882: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xB9
Feb 9 01:09:40.906: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xB9
Cause i = 0x8281 - Unallocated/unassigned number
Feb 9 01:09:44.230: ISDN BR0/0/0 Q931: TX -> RELEASE pd = 8 callref = 0x39
Feb 9 01:09:44.282: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xB9
As you can see the called-party number is being truncated after the 20th digit (unless this is just a limitation of the debug output).
It's not appropriate for me to do call forwarding within CCME itself, because I want this to take effect if the CCME box fails, so it needs to be enacted by the CO. (and also since CCME doesn't appear to support partial reroute/call deflection, every time it forwards a call, 2 BRI channels are hogged.)
Does anyone have any advice on this? Am I shagged?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Dialing long numbers over ISDN BRI
Rarely you are shagged using cisco gear.
Please configure " isdn number called enbloc " to overcome the limit of 20 digits that you've experienced.
Remember to rate useful posts.
Community Member
This is exactly what I needed - thanks.
The call-forward is still broken, but I can now take this up with the telco.
263
