Community Member
Dialing numbers gets stuck on "connecting"
Dialing certain numbers on our Cisco phones gets stuck at "connecting".  Sometimes it drops after a few seconds, and sometimes it gets stuck there until you press the end key.  RTM doesn't even show that the call was placed.
We are running CUCM 9.1 (phone versions 9.3.1SR1.1).  Anyone have an idea on what is going on?
Thanks in advance!
How long do you wait for? The default T302 timer is 15 seconds
Yosh
HTH Regards, Yosh
Community Member
We've tried waiting for 30+ seconds and it stays on "connecting".  We would dial another number with the same (area code) and same first 3 digits and it would dial within a second.
Can you try getting us the debugs from the gateway?
debug isdn q931
Kevin
97
