Silver
Dialing to PSTN via FXO
I am unable to dial to any PSTN number from my internal extension 1001. I am using CME. The PSTN line to the FXO port has the number 05222635454.
My dial plan is correct and its shows success in debug.
Posted by WebUser Vikas Mishra from Cisco Support Community App
Can you share your show run with us.
Also have you confirmed that you and plug in an analog phone to the FXO.  Also can you see the FXO port get selected when you dial... aka the light on the port goes on.
Also do a show inventory
Hall of Fame Super Silver
Post your "sh run" and "debug vpm singal" and "debug voice ccapi inout".
HTH,
Chris
Silver
This is a part of the configuration. I am able to receive incoming calls from PSTN on 1001 but unable to dial them from 1001.
voice translation-rule 1
rule 1 /1[0-9][0-9][0-9]/ /2635454/
voice translation-profile CHANGE_ANI
translate calling 1
voice-port 0/0/0
connection plar 1001
voice-port 0/0/1
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
dial-peer voice 1 pots
translation-profile outgoing CHANGE_ANI
destination-pattern T
no digit-strip
port 0/0/0
telephony-service
max-ephones 4
max-dn 6
ip source-address 192.168.83.70 port 2000
create cnf-files version-stamp 7960 Aug 13 2013 11:19:51
max-conferences 4 gain -6
ephone-dn 1
number 1001
ephone 1
mac-address 0023.0434.76E6
button 1:1
Vikas
Where are the debugs requested? And what is the detination-pattern in the dial-peer? What are you dialing?
Chris
Silver
I beg your pardon, Chris but its the production environment. Will try to share the debugs as soon as possible. Further, the destination pattern was T and I was trying 2621410 which showed SUCCESS on dial peer 1.
I thought of changing my caller id 1001 to 2635454 with the help of translation-profile so that PSTN carrier takes it as the number(2635454) provided by them to the FXO port.
Please clear the concepts.
Got it, troubleshooting without debugs can only go so far, if you believe your config is good then the only logical next step is to look at the debugs to see why the call is rejected/fails. Let us know when you can get the debugs and we will review.
Also, keep in mind that the debugs I asked for are not system impacting and can be pretty safely ran on production system unless you have thousands of calls going on at the same time, which with POTS lines I find impossible.
Chris
Just add a dial-peer it will work
dial-peer voice 2 pots
destination-pattern .T
port 0/0/0
and make a call, do not add any access code or pefix number, just dial your PSTN number.
If fails just mention the tone or message you get when you try to dial PSTN number.
Silver
Hi Chris
Please see the debugs output:
2013-08-19 15:01:38 Local7.Notice 192.168.83.70 363: Aug 19 14:55:35.578 IST: %SYS-5-CONFIG_I: Configured from console by nap7 on vty0 (172.27.0.52)
2013-08-19 15:01:39 Local7.Info 192.168.83.70 364: Aug 19 14:55:36.578 IST: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.27.0.52 started - CLI initiated
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 365: Aug 19 14:56:09.986 IST: htsp_process_event: efxs_onhook_offhook htsp_setup_ind
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 366: Aug 19 14:56:09.986 IST: get_local_station_id calling num=1001 calling name= calling time=08/19 14:56 orig called=
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 367: Aug 19 14:56:09.990 IST: //-1/37B825FB801A/CCAPI/cc_api_display_ie_subfields:
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 368: cc_api_call_setup_ind_common:
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 369: cisco-username=
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 370: -
ccCallInfo IE subfields -
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 371: cisco-ani=1001
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 372: cisco-anitype=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 373: cisco-aniplan=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 374: cisco-anipi=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 375: cisco-anisi=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 376: dest=
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 377: cisco-desttype=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 378: cisco-destplan=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 379: cisco-rdie=FFFFFFFF
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 380: cisco-rdn=
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 381: cisco-rdntype=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 382: cisco-rdnplan=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 383: cisco-rdnpi=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 384: cisco-rdnsi=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 385:
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 386: cisco-redirectreason=0
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 387: Aug 19 14:56:09.990 IST: //-1/37B825FB801A/CCAPI/cc_api_call_setup_ind_common:
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 388: Interface=0x6404D024, Call Info(
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 389: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
2013-08-19 15:02:11 Local7.Debug 192.168.83.70 390: Called Number=(TON=Unknown, NPI=Unknown),
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 391: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 392: Incoming Dial-peer=20001, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 393: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 394: Aug 19 14:56:09.990 IST: //-1/37B825FB801A/CCAPI/ccCheckClipClir:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 395:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 396: In: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 397: Aug 19 14:56:09.990 IST: //-1/37B825FB801A/CCAPI/ccCheckClipClir:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 398: Out: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 399: Aug 19 14:56:09.990 IST: //14/37B825FB801A/CCAPI/cc_api_call_setup_ind_common:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 400: Set Up Event Sent;
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 401: Call Info(Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 402: Called Number=(TON=Unknown, NPI=Unknown))
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 403: Aug 19 14:56:09.990 IST: //14/37B825FB801A/CCAPI/cc_process_call_setup_ind:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 404: Event=0x64467E98
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 405: Aug 19 14:56:09.994 IST: //14/37B825FB801A/CCAPI/ccCallSetContext:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 406:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 407: Context=0x64A552A4
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 408: Aug 19 14:56:09.994 IST: //14/37B825FB801A/CCAPI/cc_process_call_setup_ind:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 409: >>>>CCAPI handed cid 14 with tag 20001 to app "_ManagedAppProcess_Default"
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 410: Aug 19 14:56:09.994 IST: //14/37B825FB801A/CCAPI/ccCallSetupAck:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 411: Call Id=14
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 412: Aug 19 14:56:09.998 IST: //14/37B825FB801A/CCAPI/cc_api_set_transfer_info:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 413: Transfer Number=, Transfer Reason=0x0
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 414: Aug 19 14:56:09.998 IST: //14/37B825FB801A/CCAPI/ccGenerateToneInfo:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 415: Stop Tone On Digit=TRUE, Tone=Dial Tone,
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 416: Tone Direction=Network, Params=0x0, Call Id=14
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 417: Aug 19 14:56:09.998 IST: //14/37B825FB801A/CCAPI/ccSetDigitTimeouts:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 418: Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 419: Aug 19 14:56:09.998 IST: //14/37B825FB801A/CCAPI/ccSetDigitTimeouts:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 420: Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 421: Aug 19 14:56:09.998 IST: //14/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 422: (callID=0xE, digit_event=0x1, enable=TRUE, consume=FALSE)
2013-08-19 15:02:12 Local7.Debug 192.168.83.70 423: Aug 19 14:56:09.998 IST: //14/37B825FB801A/CCAPI/ccCallReportDigits:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 424: Enabled=TRUE, Call Id=14
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 425: Aug 19 14:56:09.998 IST: //14/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 426: (vdbPtr=0x6404D024, callID=0xE, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 427: Aug 19 14:56:09.998 IST: //14/37B825FB801A/CCAPI/cc_api_call_report_digits_done:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 428:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 429: Enabled=TRUE, Disposition=0x0, Interface=0x6404D024, Call Id=14
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 430: Aug 19 14:56:09.998 IST: //14/37B825FB801A/CCAPI/cc_api_call_report_digits_done:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 431: Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 432: Aug 19 14:56:09.998 IST: htsp_process_event: efxs_check_auto_call
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 433: Aug 19 14:56:10.750 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_begin:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 434: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 435: Source Call Id=14, Digit=2, DigitBeginFlags=0x0,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 436: Rtp Timestamp=0xB1BC0, Rtp Expiration=0x0
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 437: Aug 19 14:56:10.750 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 438:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 439: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 440: Source Call Id=14, Digit=2, Duration=100,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 441: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 442: Aug 19 14:56:10.750 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 443: Call Entry(Handoff Depth=0)
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 444: Aug 19 14:56:10.750 IST: htsp_digit_ready(50/0/1.1): digit = 2
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 445: Aug 19 14:56:10.750 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_begin:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 446: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 447: Source Call Id=14, Digit=6, DigitBeginFlags=0x0,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 448: Rtp Timestamp=0xB98C0, Rtp Expiration=0x0
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 449: Aug 19 14:56:10.754 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 450:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 451: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 452: Source Call Id=14, Digit=6, Duration=100,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 453: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 454: Aug 19 14:56:10.754 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 455: Call Entry(Handoff Depth=0)
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 456: Aug 19 14:56:10.754 IST: htsp_digit_ready(50/0/1.1): digit = 6
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 457: Aug 19 14:56:11.006 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_begin:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 458: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 459: Source Call Id=14, Digit=2, DigitBeginFlags=0x0,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 460: Rtp Timestamp=0xC15C0, Rtp Expiration=0x0
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 461: Aug 19 14:56:11.006 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 462:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 463: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 464: Source Call Id=14, Digit=2, Duration=100,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 465: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 466: Aug 19 14:56:11.006 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 467: Call Entry(Handoff Depth=0)
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 468: Aug 19 14:56:11.006 IST: htsp_digit_ready(50/0/1.1): digit = 2
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 469: Aug 19 14:56:11.258 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_begin:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 470: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 471: Source Call Id=14, Digit=1, DigitBeginFlags=0x0,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 472: Rtp Timestamp=0xC92C0, Rtp Expiration=0x0
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 473: Aug 19 14:56:11.258 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 474:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 475: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 476: Source Call Id=14, Digit=1, Duration=100,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 477: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 478: Aug 19 14:56:11.258 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 479: Call Entry(Handoff Depth=0)
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 480: Aug 19 14:56:11.258 IST: htsp_digit_ready(50/0/1.1): digit = 1
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 481: Aug 19 14:56:11.258 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_begin:
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 482: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 487: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 488: Source Call Id=14, Digit=4, Duration=100,
2013-08-19 15:02:13 Local7.Debug 192.168.83.70 489: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 490: Aug 19 14:56:11.262 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 491: Call Entry(Handoff Depth=0)
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 492: Aug 19 14:56:11.262 IST: htsp_digit_ready(50/0/1.1): digit = 4
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 493: Aug 19 14:56:11.514 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_begin:
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 494: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 495: Source Call Id=14, Digit=1, DigitBeginFlags=0x0,
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 496: Rtp Timestamp=0xD8CC0, Rtp Expiration=0x0
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 497: Aug 19 14:56:11.514 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 498:
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 499: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 500: Source Call Id=14, Digit=1, Duration=100,
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 501: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 502: Aug 19 14:56:11.514 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 503: Call Entry(Handoff Depth=0)
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 504: Aug 19 14:56:11.514 IST: htsp_digit_ready(50/0/1.1): digit = 1
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 505: Aug 19 14:56:11.766 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_begin:
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 506: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 507: Source Call Id=14, Digit=0, DigitBeginFlags=0x0,
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 508: Rtp Timestamp=0xE09C0, Rtp Expiration=0x0
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 509: Aug 19 14:56:11.766 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 510:
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 511: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 512: Source Call Id=14, Digit=0, Duration=100,
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 513: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 514: Aug 19 14:56:11.766 IST: //14/37B825FB801A/CCAPI/cc_api_call_digit_end:
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 515: Call Entry(Handoff Depth=0)
2013-08-19 15:02:14 Local7.Debug 192.168.83.70 516: Aug 19 14:56:11.766 IST: htsp_digit_ready(50/0/1.1): digit = 0
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 517: Aug 19 14:56:21.764 IST: //14/37B825FB801A/CCAPI/cc_handle_inter_digit_timer:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 518: Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 519: Aug 19 14:56:21.764 IST: //14/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 520: (callID=0xE, digit_event=0x0, enable=FALSE, consume=FALSE)
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 521: Aug 19 14:56:21.764 IST: //14/37B825FB801A/CCAPI/ccCallReportDigits:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 522: Enabled=TRUE, Call Id=14
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 523: Aug 19 14:56:21.764 IST: //14/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 524: (vdbPtr=0x6404D024, callID=0xE, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 525: Aug 19 14:56:21.764 IST: //14/37B825FB801A/CCAPI/cc_api_call_report_digits_done:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 526: Enabled=TRUE, Disposition=0x0, Interface=0x6404D024, Call Id=14
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 527: Aug 19 14:56:21.764 IST: //14/37B825FB801A/CCAPI/cc_api_call_report_digits_done:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 528: Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 529: Aug 19 14:56:21.764 IST: //14/37B825FB801A/CCAPI/ccCallProceeding:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 530: Progress Indication=NULL(0)
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 531: Aug 19 14:56:21.768 IST: //14/37B825FB801A/CCAPI/ccCallSetupRequest:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 532: Destination=, Calling IE Present=TRUE, Mode=0,
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 533: Outgoing Dial-peer=1, Params=0x64A55F54, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 534: Aug 19 14:56:21.768 IST: //14/37B825FB801A/CCAPI/ccCheckClipClir:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 535: In: Calling Number=2635454(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 536: Aug 19 14:56:21.768 IST: //14/37B825FB801A/CCAPI/ccCheckClipClir:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 537: Out: Calling Number=2635454(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 538: Aug 19 14:56:21.768 IST: //14/37B825FB801A/CCAPI/ccCallSetupRequest:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 539: Destination Pattern=[0-9]T, Called Number=2621410, Digit Strip=FALSE
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 540: Aug 19 14:56:21.768 IST: //14/37B825FB801A/CCAPI/ccCallSetupRequest:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 541: Calling Number=2635454(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 542: Called Number=2621410(TON=Unknown, NPI=Unknown),
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 543: Redirect Number=, Display Info=
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 544: Account Number=, Final Destination Flag=FALSE,
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 545: Guid=37B825FB-07E8-11E3-801A-9EEC50A56F17, Outgoing Dial-peer=1
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 546: Aug 19 14:56:21.768 IST: //14/37B825FB801A/CCAPI/cc_api_display_ie_subfields:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 547: ccCallSetupRequest:
2013-08-19 15:02:23 Local7.Debug 192.168.83.70 548: cisco-username=
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 549: -
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 550: cisco-ani=2635454
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 551: cisco-anitype=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 552: cisco-aniplan=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 553: cisco-anipi=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 554: cisco-anisi=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 555: dest=2621410
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 556: cisco-desttype=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 557: cisco-destplan=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 558: cisco-rdie=FFFFFFFF
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 559: cisco-rdn=
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 560: cisco-rdntype=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 561: cisco-rdnplan=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 562: cisco-rdnpi=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 563: cisco-rdnsi=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 564: cisco-redirectreason=0
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 565: Aug 19 14:56:21.768 IST: //14/37B825FB801A/CCAPI/ccIFCallSetupRequestPrivate:
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 566:
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 567: Interface=0x644A6CC8, Interface Type=6, Destination=, Mode=0x0,
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 568: Call Params(Calling Number=2635454(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 569: Called Number=2621410(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 570: Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=1, Call Count On=FALSE,
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 571: Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 572: Aug 19 14:56:21.768 IST: //15/37B825FB801A/CCAPI/ccIFCallSetupRequestPrivate:
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 573: SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 574: Aug 19 14:56:21.768 IST: //15/37B825FB801A/CCAPI/ccCallSetContext:
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 575:
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 576: Context=0x64A55F04
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 577: Aug 19 14:56:21.768 IST: //14/37B825FB801A/CCAPI/ccSaveDialpeerTag:
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 578: Outgoing Dial-peer=1
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 579: Aug 19 14:56:21.772 IST: htsp_timer_stop3
2013-08-19 15:02:24 Local7.Debug 192.168.83.70 587: Interface=0x644A6CC8, Progress Indication=NULL(0)
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 588: Aug 19 14:56:31.774 IST: htsp_process_event: fxogs_offhook_disc
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 589: Aug 19 14:56:31.774 IST: htsp_timer_stop
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 590: Aug 19 14:56:31.774 IST: set signal state = 0x4 timestamp = 0
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 591: Aug 19 14:56:31.774 IST: htsp_timer - 2000 msec
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 592: Aug 19 14:56:31.774 IST: //15/37B825FB801A/CCAPI/cc_api_call_disconnected:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 593: Cause Value=16, Interface=0x644A6CC8, Call Id=15
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 594: Aug 19 14:56:31.774 IST: //15/37B825FB801A/CCAPI/cc_api_call_disconnected:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 595: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 596: Aug 19 14:56:31.774 IST: //15/37B825FB801A/CCAPI/ccCallSetAAA_Accounting:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 597: Accounting=0, Call Id=15
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 598: Aug 19 14:56:31.774 IST: //15/37B825FB801A/CCAPI/ccCallDisconnect:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 599: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 600: Aug 19 14:56:31.774 IST: //15/37B825FB801A/CCAPI/ccCallDisconnect:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 601: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 602: Aug 19 14:56:31.774 IST: //15/37B825FB801A/CCAPI/cc_api_get_transfer_info:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 603: Transfer Number Is Null
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 604: Aug 19 14:56:31.774 IST: htsp_process_event: fxogs_onhook_release
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 605: Aug 19 14:56:31.774 IST: htsp_timer_stop2
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 606: Aug 19 14:56:31.778 IST: htsp_timer_stop3
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 607: Aug 19 14:56:31.778 IST: //15/37B825FB801A/CCAPI/cc_api_call_disconnect_done:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 608:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 609: Disposition=0, Interface=0x644A6CC8, Tag=0x0, Call Id=15,
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 610: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 611: Aug 19 14:56:31.778 IST: //15/37B825FB801A/CCAPI/cc_api_call_disconnect_done:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 612: Call Disconnect Event Sent
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 613: Aug 19 14:56:31.778 IST: //14/37B825FB801A/CCAPI/ccCallDisconnect:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 614: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 615: Aug 19 14:56:31.782 IST: //14/37B825FB801A/CCAPI/ccCallDisconnect:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 616: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 617: Aug 19 14:56:31.782 IST: //14/37B825FB801A/CCAPI/cc_api_get_transfer_info:
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 618: Transfer Number Is Null
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 619: Aug 19 14:56:31.782 IST: htsp_process_event: efxs_offhook_disc
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 620: Aug 19 14:56:31.782 IST: htsp_timer_stop
2013-08-19 15:02:33 Local7.Debug 192.168.83.70 621: Aug 19 14:56:31.782 IST: set signal state = 0x4 timestamp = 0
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 622: Aug 19 14:56:31.782 IST: set signal state = 0xC timestamp = 0
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 623: Aug 19 14:56:31.782 IST: set signal state = 0x4 timestamp = 10
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 624: Aug 19 14:56:31.782 IST: htsp_timer - 10 msec
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 625: Aug 19 14:56:31.794 IST: htsp_process_event: efxs_cpc_timer
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 626: Aug 19 14:56:31.794 IST: htsp_timer - 30000 msec
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 627: Aug 19 14:56:31.794 IST: htsp_process_event: efxs_waitonhook_onhook
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 628: Aug 19 14:56:31.794 IST: htsp_timer_stop htsp_report_onhook_sig
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 629: Aug 19 14:56:31.798 IST: //14/37B825FB801A/CCAPI/cc_api_call_disconnect_done:
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 630: Disposition=0, Interface=0x6404D024, Tag=0x0, Call Id=14,
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 631: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 632: Aug 19 14:56:31.798 IST: //14/37B825FB801A/CCAPI/cc_api_call_disconnect_done:
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 633: Call Disconnect Event Sent
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 634: Aug 19 14:56:32.042 IST: htsp_process_event:
2013-08-19 15:02:34 Local7.Debug 192.168.83.70 635: Aug 19 14:56:32.042 IST: fxogs_line_reversal_clid_wait. On_hook line reversal detected possibily due to crossed cable
2013-08-19 15:02:36 Local7.Debug 192.168.83.70 636: Aug 19 14:56:33.773 IST: htsp_process_event:
2013-08-19 15:05:34 Local7.Debug 192.168.83.70 637: Aug 19 14:59:31.761 IST: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
2013-08-19 15:05:34 Local7.Debug 192.168.83.70 638: ccAppShutdownMode: remove it from the queue
2013-08-19 15:14:13 Local7.Notice 192.168.83.70 639: Aug 19 15:08:06.094 IST: %SYS-5-CONFIG_I: Configured from console by nap7 on vty0 (172.27.0.52)
2013-08-19 15:14:14 Local7.Info 192.168.83.70 640: Aug 19 15:08:12.093 IST: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.27.0.52 stopped - CLI initiated
2013-08-19 15:14:14 Local7.Info 192.168.83.70 641: Aug 19 15:08:12.093 IST: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.27.0.52 started - CLI initiated
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 642: Aug 19 15:10:11.316 IST: htsp_process_event: fxogs_onhook_ringing
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 643: Aug 19 15:10:11.316 IST: htsp_timer_stop
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 644: Aug 19 15:10:11.316 IST: htsp_timer - 125 msec
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 645: Aug 19 15:10:11.444 IST: htsp_process_event: fxogs_wait_ring_min_timer
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 646: Aug 19 15:10:11.444 IST: htsp_timer - 10000 msec
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 647: Aug 19 15:10:11.612 IST: htsp_process_event:
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 648: Aug 19 15:10:11.612 IST: fxogs_ringing_not:
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 649: Aug 19 15:10:11.612 IST: htsp_timer_stop
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 650: Aug 19 15:10:11.612 IST: htsp_timer_stop2
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 651: Aug 19 15:10:11.612 IST: htsp_timer_stop3 htsp_setup_ind
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 652: Aug 19 15:10:11.612 IST: get_local_station_id calling num= calling name= calling time=08/19 15:10 orig called=
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 653: Aug 19 15:10:11.616 IST: //-1/2D5DF83E801D/CCAPI/cc_api_display_ie_subfields:
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 654: cc_api_call_setup_ind_common:
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 655: cisco-username=
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 656: -
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 657: cisco-ani=
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 658: cisco-anitype=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 659: cisco-aniplan=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 660: cisco-anipi=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 661: cisco-anisi=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 662: dest=1001
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 663: cisco-desttype=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 664: cisco-destplan=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 665: cisco-rdie=FFFFFFFF
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 666: cisco-rdn=
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 667: cisco-rdntype=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 668: cisco-rdnplan=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 669: cisco-rdnpi=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 670: cisco-rdnsi=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 671: cisco-redirectreason=0
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 672: Aug 19 15:10:11.616 IST: //-1/2D5DF83E801D/CCAPI/cc_api_call_setup_ind_common:
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 673:
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 674: Interface=0x644A6CC8, Call Info(
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 675: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 676: Called Number=1001(TON=Unknown, NPI=Unknown),
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 677: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 678: Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 679: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
2013-08-19 15:16:13 Local7.Debug 192.168.83.70 680: Aug 19 15:10:11.616 IST: //-1/2D5DF83E801D/CCAPI/ccCheckClipClir:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 681: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 682: Aug 19 15:10:11.616 IST: //-1/2D5DF83E801D/CCAPI/ccCheckClipClir:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 683: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 684: Aug 19 15:10:11.616 IST: //16/2D5DF83E801D/CCAPI/cc_api_call_setup_ind_common:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 685: Set Up Event Sent;
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 686: Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 687: Called Number=1001(TON=Unknown, NPI=Unknown))
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 688: Aug 19 15:10:11.616 IST: htsp_process_event:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 689: Aug 19 15:10:11.620 IST: fxogs_wait_setup_ack:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 690: Aug 19 15:10:11.620 IST: set signal state = 0xC timestamp = 0
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 691: Aug 19 15:10:11.620 IST: //16/2D5DF83E801D/CCAPI/cc_process_call_setup_ind:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 692: Event=0x64467E98
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 693: Aug 19 15:10:11.620 IST: //16/2D5DF83E801D/CCAPI/ccCallSetContext:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 694: Context=0x64A56B64
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 695: Aug 19 15:10:11.620 IST: //16/2D5DF83E801D/CCAPI/cc_process_call_setup_ind:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 696: >>>>CCAPI handed cid 16 with tag 1 to app "_ManagedAppProcess_Default"
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 697: Aug 19 15:10:11.624 IST: //16/2D5DF83E801D/CCAPI/ccCallProceeding:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 698: Progress Indication=NULL(0)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 699: Aug 19 15:10:11.624 IST: //16/2D5DF83E801D/CCAPI/ccCallSetupRequest:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 700: Destination=, Calling IE Present=FALSE, Mode=0,
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 701: Outgoing Dial-peer=20001, Params=0x64A57814, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 702: Aug 19 15:10:11.624 IST: //16/2D5DF83E801D/CCAPI/ccCheckClipClir:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 703: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 704: Aug 19 15:10:11.624 IST: //16/2D5DF83E801D/CCAPI/ccCheckClipClir:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 705: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 706: Aug 19 15:10:11.624 IST: //16/2D5DF83E801D/CCAPI/ccCallSetupRequest:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 753: Aug 19 15:10:11.632 IST: htsp_ephone_start_caller_id_tx calling num= calling name = called num=1001 orig called num=
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 754: Aug 19 15:10:11.632 IST: set signal state = 0x0 timestamp = 0
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 755: Aug 19 15:10:11.884 IST: efxs_onhook_setup: local target is available
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 756: htsp_alert
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 757: Aug 19 15:10:11.884 IST: //17/2D5DF83E801D/CCAPI/cc_api_call_proceeding:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 758: Interface=0x6404D024, Progress Indication=NULL(0)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 759: Aug 19 15:10:11.884 IST: //17/2D5DF83E801D/CCAPI/cc_api_call_alert:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 760: Interface=0x6404D024, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 761: Aug 19 15:10:11.884 IST: //17/2D5DF83E801D/CCAPI/cc_api_call_alert:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 762: Call Entry(Retry Count=0, Responsed=TRUE)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 763: Aug 19 15:10:11.884 IST: //16/2D5DF83E801D/CCAPI/ccCallAlert:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 764: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 765: Aug 19 15:10:11.884 IST: //16/2D5DF83E801D/CCAPI/ccCallAlert:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 766: Call Entry(Responsed=TRUE, AlertSent=TRUE)htsp_alert_notify
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 767: Aug 19 15:10:11.888 IST: htsp_process_event:
2013-08-19 15:16:14 Local7.Debug 192.168.83.70 768: Aug 19 15:10:11.892 IST: htsp_process_event:
2013-08-19 15:17:32 Local7.Debug 192.168.83.70 769: Aug 19 15:11:31.191 IST: htsp_process_event: efxs_waitoff_offhook
2013-08-19 15:17:32 Local7.Debug 192.168.83.70 770: Aug 19 15:11:31.191 IST: set signal state = 0x4 timestamp = 0 htsp_dial
2013-08-19 15:17:32 Local7.Debug 192.168.83.70 771: Aug 19 15:11:31.191 IST: //17/2D5DF83E801D/CCAPI/cc_api_call_connected:
2013-08-19 15:17:32 Local7.Debug 192.168.83.70 772: Interface=0x6404D024, Data Bitmask=0x1, Progress Indication=NULL(0),
2013-08-19 15:17:32 Local7.Debug 192.168.83.70 773: Connection Handle=0
2013-08-19 15:17:32 Local7.Debug 192.168.83.70 774: Aug 19 15:11:31.191 IST: //17/2D5DF83E801D/CCAPI/cc_api_call_connected:
2013-08-19 15:17:32 Local7.Debug 192.168.83.70 775: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
2013-08-19 15:17:33 Local7.Debug 192.168.83.70 776: Aug 19 15:11:31.191 IST: htsp_process_event:
2013-08-19 15:17:33 Local7.Debug 192.168.83.70 777: Aug 19 15:11:31.195 IST: //16/2D5DF83E801D/CCAPI/ccGenerateToneInfo:
2013-08-19 15:17:33 Local7.Debug 192.168.83.70 778:
2013-08-19 15:17:33 Local7.Debug 192.168.83.70 779: Stop Tone On Digit=FALSE, Tone=Null,
2013-08-19 15:17:33 Local7.Debug 192.168.83.70 780: Tone Direction=Network, Params=0x0, Call Id=16
2013-08-19 15:17:33 Local7.Debug 192.168.83.70 781: Aug 19 15:11:31.195 IST: //16/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
2013-08-19 15:17:33 Local7.Debug 192.168.83.70 782: (confID=0x64ABD368, callID1=0x10, callID2=0x11, tag=0x0)
2013-08-19 15:17:33 Local7.Debug 192.168.83.70 783: Aug 19 15:11:31.195 IST: //16/2D5DF83E801D/CCAPI/ccConferenceCreate:
2013-08-19 15:17:33 Local7.Debug 192.168.83.70 784: Conference Id=0x64ABD368, Call Id1=16, Call Id2=17, Tag=0x0
2013-08-19 15:17:56 Local7.Debug 192.168.83.70 785: Aug 19 15:11:31.195 IST: htsp_call_bridged invoked
2013-08-19 15:17:56 Local7.Debug 192.168.83.70 786: Aug 19 15:11:31.195 IST: //16/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
2013-08-19 15:17:57 Local7.Debug 192.168.83.70 787: Conference Id=0x3, Source Interface=0x644A6CC8, Source Call Id=16,
2013-08-19 15:17:57 Local7.Debug 192.168.83.70 788: Destination Call Id=17, Disposition=0x0, Tag=0xFFFFFFFF
2013-08-19 15:17:57 Local7.Debug 192.168.83.70 789: Aug 19 15:11:31.195 IST: htsp_call_bridged invoked
2013-08-19 15:17:57 Local7.Debug 192.168.83.70 790: Aug 19 15:11:31.195 IST: //17/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
2013-08-19 15:17:57 Local7.Debug 192.168.83.70 791: Conference Id=0x3, Source Interface=0x6404D024, Source Call Id=17,
2013-08-19 15:17:58 Local7.Debug 192.168.83.70 792: Destination Call Id=16, Disposition=0x0, Tag=0xFFFFFFFF
2013-08-19 15:17:58 Local7.Debug 192.168.83.70 793: Aug 19 15:11:31.195 IST: //16/2D5DF83E801D/CCAPI/cc_generic_bridge_done:
2013-08-19 15:17:58 Local7.Debug 192.168.83.70 794: Conference Id=0x3, Source Interface=0x6404D024, Source Call Id=17,
2013-08-19 15:17:58 Local7.Debug 192.168.83.70 795: Destination Call Id=16, Disposition=0x0, Tag=0xFFFFFFFF
2013-08-19 15:17:58 Local7.Debug 192.168.83.70 796: Aug 19 15:11:31.195 IST: //16/2D5DF83E801D/CCAPI/ccConferenceCreate:
2013-08-19 15:17:58 Local7.Debug 192.168.83.70 797: Call Entry(Conference Id=0x3, Destination Call Id=17)
2013-08-19 15:17:58 Local7.Debug 192.168.83.70 798: Aug 19 15:11:31.195 IST: //17/2D5DF83E801D/CCAPI/ccConferenceCreate:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 799: Call Entry(Conference Id=0x3, Destination Call Id=16)
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 800: Aug 19 15:11:31.195 IST: //16/2D5DF83E801D/CCAPI/cc_api_caps_ind:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 801: Destination Interface=0x6404D024, Destination Call Id=17, Source Call Id=16,
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 802: Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 803: Modem=0x2, Codec Bytes=160, Signal Type=2)
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 804: Aug 19 15:11:31.195 IST: //16/2D5DF83E801D/CCAPI/cc_api_caps_ind:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 805: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 806: Playout Max=250(ms), Fax Nom=300(ms))
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 807: Aug 19 15:11:31.195 IST: //17/2D5DF83E801D/CCAPI/cc_api_caps_ind:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 808: Destination Interface=0x644A6CC8, Destination Call Id=16, Source Call Id=17,
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 809: Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 810: Modem=0x2, Codec Bytes=160, Signal Type=2)
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 811: Aug 19 15:11:31.195 IST: //17/2D5DF83E801D/CCAPI/cc_api_caps_ind:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 812: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 813: Playout Max=250(ms), Fax Nom=300(ms))
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 814: Aug 19 15:11:31.195 IST: //17/2D5DF83E801D/CCAPI/cc_api_caps_ack:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 815: Destination Interface=0x644A6CC8, Destination Call Id=16, Source Call Id=17,
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 816: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 817: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9441)
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 818: Aug 19 15:11:31.199 IST: //16/2D5DF83E801D/CCAPI/cc_api_caps_ack:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 819:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 820: Destination Interface=0x6404D024, Destination Call Id=17, Source Call Id=16,
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 821: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 822: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6423)
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 823: Aug 19 15:11:31.199 IST: //17/2D5DF83E801D/CCAPI/cc_api_voice_mode_event:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 824: Call Id=17
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 825: Aug 19 15:11:31.199 IST: //17/2D5DF83E801D/CCAPI/cc_api_voice_mode_event:
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 826: Call Entry(Context=0x64A577C4)
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 827: Aug 19 15:11:31.199 IST: htsp_process_event: efxs_connect_cutthru
2013-08-19 15:17:59 Local7.Debug 192.168.83.70 828: Aug 19 15:11:31.199 IST: set signal state = 0x7 timestamp = 0
2013-08-19 15:18:00 Local7.Debug 192.168.83.70 829: Aug 19 15:11:31.199 IST: //16/2D5DF83E801D/CCAPI/cc_process_notify_bridge_done:
2013-08-19 15:18:00 Local7.Debug 192.168.83.70 830: Conference Id=0x3, Call Id1=16, Call Id2=17
2013-08-19 15:18:00 Local7.Debug 192.168.83.70 839: Call Entry(Context=0x64A56B64)
2013-08-19 15:18:00 Local7.Debug 192.168.83.70 840: Aug 19 15:11:31.207 IST: htsp_process_event:
Vikas
ANI 2635454
DNIS 2621410
Dial-peer 1
destination-pattern [0-9]T
is it the right information, is the dialed number is some thing else than DNIS
Silver
Hi Chris,
What do you observe from these?
Silver
Hi Chris
Please reply to the debugs I sent you.
See this:
change polarity on your cable and also test with group start.
HTH,
Chris
581
