Diall-peer issue
Can someone help me with the folloing dial-peer problem?
CallManager Ver6 withh voip Gateway
- when i dial internatioal call 000.... it are using some time voip and other time pots dial peer :
The router pater its oK
dial-peer voice 1 pots
destination-pattern 0T
port 0/0/0:15
dial-peer voice 8 pots
description ** BRI pots dial-peer **
translation-profile incoming 2300
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 4 pots
destination-pattern 000T
port 0/0/0:15
prefix 00
dial-peer voice 500 voip
destination-pattern 5..
session target ipv4:172.19.101.99
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 2301 pots
direct-inward-dial
port 0/0/0:15
dial-peer voice 2300 voip
destination-pattern 2602...
session target ipv4:172.19.0.253
codec transparent
dial-peer voice 300 voip
destination-pattern 3..
codec transparent
no vad
Re: Diall-peer issue
at least looking at the dial-peers you posted there is no possibility it could use a VoIP dial-peer, destination patterns simply do not match.
check how many digits and what digits you're sending from CUCM to see what dial-peer they would match.
you can run a debug voip ccapi inout to see the whole process of what GW receives and processes, dial-peers matched will be shown there
java
if this helps, please rate
java
www.cisco.com/go/pdi
Can you post "show dial-peer voice summary"? This is the best way to look at the dial plan.
As well, do a 'debug voip dialpeer' for both the good and the bad calls and make sure the numbers are as you expect them.
It looks like you have an overlapping dial plan between dial peer 1 and 4. I wouldn't be surprised if it was load balancing between those two dial peers. Changing that would require changing the way you dial one of those two types of numbers.
Additionally, they're doing the same thing. You could get rid of dial peer 4 completely.
hth,
nick
-nick
I putting in attachments the voip ccapi debug - showing a call to 000351.........
using Voip Dial peer. I am not seeing why its happining
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT
PORT
500 voip up up 5.. 0 syst ipv4:172.19.101.99
2301 pots up up 0 down
0/0/0:15
4 pots up up 00 000T 0 up
0/0/0:15
1 pots up up 0T 0 up
0/0/0:15
8 pots up up 0 down
0/0/0:15
2300 voip up up 2602... 0 syst ipv4:172.19.0.253
300 voip up up 3.. 0 syst ipv4:172.19.0.253
Me again to add a voice dial-peer debug
What happens if you do this:
dial-p v 1
preference 1
or
dial-p v 4
preference 2
These dial peers are being matched for both types of international and normal calls.
-nick
I continue tha have the 000... call match with the voip DP 2300
VIP Super Bronze
Here is your problem...When a call is passed from Callmanager to a Voice gateway, it uses a voip dial-peer leg. In normal situations, you should have an incoming voip dial-peer just as you have for incoming pots dial-peer.
Your call leg in this situation will be 2..One coming from callmanager to the gateway and the other from the gateway to the PSTN.
In this case, the gateway is using the dial-peer 2300 which has incoming called number. (because th . aloow all calls) as its incoming dial-peer and using dial-peer 4 for outbound calls.
To resolve this porblem, configure the following
dial-peer voice 99999 voip
voice-class codec 1
fax rate disable
no vad
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
I keep all the dial-peer and add this one but the problem is the same
This is an incoming dial peer. It is completely different than an outgoing dial peer.
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
hth,
nick
Hi the link ask me a password and user name
VIP Super Bronze
Did you see this post I sent to you...
voice-class codec 1
fax rate disable
no vad
Yes
I added this dial-peer bu the problem is still the same
VIP Super Bronze
OK..add the command preference 1 under this dial-peer and preference 2 under the pots dial-peer
so you will have
dial-peer voice 9999 voip
incoming called-number.
preference 1
and dial-peer voice 4 pots
preference 2
then do a debug voip caapi inout and post the out put here..pls do this quickly...need to go home (waiting cos of you:)
Hi I hope you still there
The problem continue
VIP Super Bronze
Dont reboot the router..you have configured your incoming dial-peer 2300 voip wrongly. You should not have any destination-pattern on it. If you do all your calls from callmanager will be sent back to that destination pattern address...Which I believe is callmanager!
VIP Super Bronze
Afro,
do 2 things
1. Either remove the incoming called-number . from the dial-peer 2300 or remove the destination-pattern from it.
if you remove the incoming called-number . from it, create a new dial-peer as I told you before. No destination pattern on it
No its using always the dp 99999 but the call cannot complety
And Now I can make a call to 0001508....... (USA) but to 000351.........(PORTUGAL) its no possible
VIP Super Bronze
Ok.
send debug output
This may actual dial-peerdial-peer voice 2301 pots
direct-inward-dial
port 0/0/0:15
port 0/0/0:15
direct-inward-dial
port 0/0/0:15
preference 4
codec transparent
no vad
preference 1
voice-class codec 1
fax rate disable
no vad
preference 2
destination-pattern .
codec transparent
dial-peer voice 2 pots
destination-pattern 000351T
port 0/0/0:15
prefix 00351
Now the situation is no so bad
Some time tha call are using the right dial-peer but other time it use the 2300 for outgoing. In the case the call are ring in an internal Phone withe the last 3 digit .I meas if I call 000351961245313 the call ring in the IP Phone 313
In attach the debug for boot situation
VIP Super Bronze
You need to remove this dial-peer config. You dont need it and its causing you problems. This is why your calls are ringing on ip phone 313. Because all calls coming from callmanager is going back to callmanager
preference 2
codec transparent
This dial-peer is used to receive incoming DDI call
If I remove it the incoming DDI call from outsid stop to work
VIP Super Bronze
Nooooooooooooooooooooooooooo! The dial-peer used to receive incoming DDI is this
direct-inward-dial
port 0/0/0:15
You dont need that one! dial-peer 2300!
Sure but the call will stop at the Gateway , dont came to callmanager
Please clarify me if I am wrong
VIP Super Bronze
Ok I see that yoiu have changed the destination pattern. on dial-peer 2300. Ok you can leave it but remove the comand "incoming called number." on it.
This is the way it works. Calls coming from outside will first of all match dial-peer 2301, after that they will then match either
codec transparent
no vad
or
codec transparent
no vad
Depending on the number called.
Calls from callmanager will macth dial-peer 9999 voip.
Hi aokanlawon
Last two days i was having a problem with date an time , my Call Manager was not accepting the 31 March 2009.
Some one adive here in forum that is a CCM 6.0 bug
I still having a dial-peer problem
But I heady now to continue fixing this issue
For this moment the situation its not so bad
All the call to outid is using dial-peer 1 but concerning to the patern 000351.......... I stil continus having a problem , some time the call can be done and other not
port 0/0/0:15
Concerning the dial peer to DID
preference 4
destination-pattern 26023..
codec transparent
I try remove the "destination-pattern 26023.." bu the call stop on the Gateway , I means dont go to the dialed Ext
Hi Oak
How are you
Did you see my last message?
Brgds
230
