Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Dialling Error
CM version 4.13
I have a publisher and 2 subscribers. I installed the 2nd subscriber and all phones have registered to it. but it seems that any phone that had a callforward can no not be dialled or call out , I have reset the DBL monitor and CTI manager but still I can't call these phones neither can they dial out. Replication looks good. any ideas?
1 REPLY
Bronze
Re: Dialling Error
Try dblhelper which is usually part of your CM install so just do a search on the HD or download the upgrade prep tool to 4.3 and let it do a sanity check on your CM4.1
CCMUpgdAsstInstall.4-3-4.exe
CUCM Upgrade Utility (UA),
Below is a tech note on forwarding issues
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801b3f4b.shtml
did you check for a Partition/calling Search Space issue?
115
