Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
dialpeer preference
Will the following configuration work? I want to use pots as backup if the gk goes down. However I have to use generic pattern [2-9]......... otherwise I have to configure a lot of peers. I guess backup only works when the pattern exact same, right? Otherwise call to 25379..... always use pots peer not voip peer?
dial-peer voice 1 voip
destination-pattern [2-9].........
session target ras
incoming called-number .
dtmf-relay h245-alphanumeric
dial-peer voice 14 pots
destination-pattern 25379.....
port 0/0:23
preference 2
Gold
Re: dialpeer preference
preference would only be used when there is a tie between multiple dial-peers. With the configuration you have posted it will always hit dial-peer 14 as that is a more specific match. If you replace destination-pattern to use on dial-peer 14 to use the same as dial-peer 1, it should work for you. Once that is done, since both have the same destination pattern, the router would use preference, and if preference is also the same, it would then try using the first dial-peer configured.
Hall of Fame Super Gold
Small correction to the good advice above: Among DPs of same preference for same destination, IOS will choose the least-used, that is the one with the older timestamp for a completed call. In practice, round-robin.
Really? Cisco supports round robin? Just use same preference, no other commands?
Really. It happens that cisco supports a lot of things :)
319
