DID dial-plan conflict
I have a location who's DID numbers are 9600-9699 there extension numbers on there phones are 5600-5699. The telco is pulsing in 3 digits. I am wanting to do a translation rule to take the 3 digits pulsing in from the telco and ring the 5XXX extension number in CUCM. I am wanting to do this in there 2811 router so that it will work even in SRST. I am new to translations so please be clear.
Re: DID dial-plan conflict
Here ya go...
voice translation-rule 1
rule 1 /*/ /5/
voice translation-profile prefix5
translate called 1
The apply 'translation-profile incoming prefix5' to your inbound call leg dial-peer.
Chris
Thanks, I tried this and got the follow message.
mideastrtr01(cfg-translation-rule)#rule 1 /*/ /5/
% ?+* follows nothing ^
% Invalid input detected at '^' marker.
Looks like it will not take the /*/.
Any ideals?
chris
I believe that rule will not prefix 5 to your 3 digits from telco.
You need: rule 1 // /5/
Try that and let us know.
Best regards,
- Adrián.
Use this syntax -
rule 1 /^\(.*\)/ /5\1/
this will match on any lenght string , and it will prefix '5' to the front of it -
UC520-120#test voice translation-rule 1 123
Matched with rule 1
Original number: 123 Translated number: 5123
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
UC520-120#
Thanks, that is working in the router now, however it is still not ringing my phone with the extension 5650, when I dial the DID XXXXXX9650.
Here is my dial-peer do I have something wrong?
dial-peer voice 209 voip
description Local dial-peer for destination-pattern 65. to extensions 651 -
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
session target ipv4:xxx.xx.xxx.xx
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
Chris
Your destination-pattern needs the 5 also.
- Adrián.
I think you have the translation-pattern on the wrong dial-peer. This looks to be the outbound voip dialpeer. You want to put that translation pattern on the inbound pots dialpeer.
The way it's setup here, it will prepend a 5 to all calls dialed out from the CCM.
And then, yes, you would need to add a 5 to the destination pattern on the voip dialpeer.
I may be wrong but I thought Pots dial peers are outbound from the router and voip are inbound. That is the way I am using them in my config.
My pots peers point to local lines on an FXO that allows the branch to dial out local.
Correct me if I am looking at this wrong.
Chris
Every call through a voice gateway has two call legs and uses two dial-peers.
Calls from the PSTN to the VOIP system use an inbound POTS dial-peer and an outbound VOIP dial-peer, whereas calls from the VOIP system to the PSTN use an inbound VOIP dial-peer and an outbound POTS dial-peer.
In most cases, unless you intentionally create a dedicated inbound dial-peer, the same dial-peer you configure for outbound is also used for inbound in the opposite direction.
So where are these calls entering the router from the PSTN?
Hi Chris,
I don't know if you already have this documents, but if not, this could help understanding dial peers (that sometimes at beginning is a bit confusing).
Understanding Inbound and Outbound Dial Peers Matching on IOS Platforms:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Configuring Dial Plans, Dial Peers, and Digit Manipulation:
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfpeers.html
Hope it helps.
Best regards,
- Adrián.
Thanks for the information, I will take a look at it.
I was able to get this working. Each post added a little more insight to the issue.
In the end I was able to add the following statement to my VOIP dial peer.
translation-profile outgoing prefix5
This seemed to work.
Thanks 5 points to all.
Chris
463
